TOPIC: Speedi Sleeve sources?
Speedi Sleeve sources? 12 years 5 days ago #99941
  • Normspeed
  • Normspeed's Avatar Topic Author
Well I now have two trailers that could use the help of Speedi Sleeves on the axles. Their website is good and has a nice app to find the correct size. Just wondering, those of you that have bought these, is there any advantage to shopping around the web for a better price, or best to just go with a purchase direct from SKF?
(I see a winter project coming up here)
Re:Speedi Sleeve sources? 12 years 5 days ago #99943
  • frog
  • frog's Avatar
  • Thank you received: 3
norm, get a stainless steel speedie sleeve, they do make plain steel ones but you will get a rust ring on it on the outside of the seal. and the rust will work it's way onto the sealing surface. hope I didn't confuse with that. frog
Re:Speedi Sleeve sources? 12 years 4 days ago #99966
  • Normspeed
I think stainless would be best too. No sense in using less. Wouldn't want to do the job again in a few years.
Re:Speedi Sleeve sources? 12 years 4 days ago #99977
I'd shop around, but since you are not up in Canada (where for some reason the price is twice or three times as in the US), I think the price is relatively consistent. I recently bought 2 for my drive and prop shaft.
Re:Speedi Sleeve sources? 12 years 4 days ago #99979
  • Robby321
  • Robby321's Avatar
  • Thank you received: 10
Napa carries them..(or ordered at least) I gotta do one my boat trailers too. And pretty sure the are stainless anyway.
www.skf.com/group/products/seals/industrial-seals/power-transmission-seals/wear-sleeves/skf-speedi-sleeve/index.html
We have 6021 guests and one member online
