TOPIC: 74 Hydrodyne gunnel rubber replacement?
74 Hydrodyne gunnel rubber replacement? 14 years 10 months ago #53498
Anyone know a source for this?
Re:74 Hydrodyne gunnel rubber replacement? 14 years 10 months ago #53521
Welcome aboard, JRP. Can you post a pic of what you're talking about, or describe it a little more? If you mean the rub rail molding, we can hook you up with several good sources on that. ;)
Re:74 Hydrodyne gunnel rubber replacement? 14 years 6 months ago #60127
Yes Rub rail molding. It is actually a 73 Super Skier. About 19' Thanks
Re:74 Hydrodyne gunnel rubber replacement? 13 years 3 months ago #81721
I'm back at it looking for Rub Rail I'm told..still looking JP
Re:74 Hydrodyne gunnel rubber replacement? 13 years 1 month ago #84485
I had WEFCO Rubber in Canoga Park, CA make the die for the Crosby and Hydrodyne rub rail. This has got to be almost a decade ago now. On the first order we had a lot of rail made. As I recall the die # is 187-1. But call Peter at Wefco and verify that. I will check the shop this weekend to make sure I got the die # correct.
Re:74 Hydrodyne gunnel rubber replacement? 6 years 3 months ago #143001
Hey guys, have a 78 Dyne with white rub rail with black insert! Called Wefco rubber company and they only run black on black at this time! Would you have any other source on the rub rail?? Thanks Sly
We have 10566 guests and no members online
