TOPIC: Water pump cover removal tool
Water pump cover removal tool 12 years 2 months ago #98965
Anyone have the tool to remove the water pump cover on my mark 55a that I could borrow? Would pay for shipping and promise to send it back!!!!!
Lee
Re:Water pump cover removal tool 12 years 2 months ago #98966
Re:Water pump cover removal tool 12 years 2 months ago #98981
I saw some place, can't find it now, where someone had made their own tool out of an adjustable wrench. They drilled holes through each end of the forks then, inserted a bolt (appropriate size to match the diameter of the pump cover holes) and tighten with nuts. I don't know how well this works though.
Re:Water pump cover removal tool 12 years 2 months ago #98983
use flat stock steel drill hole for driveshaft the drill matching holes for cover. add bolts the correct size and you have the tool.
Re:Water pump cover removal tool 12 years 2 months ago #99037
I have one here in central CA. I warn you it is heavy. It also only has one handle but it works.
Re:Water pump cover removal tool 12 years 2 months ago #99046
I am not far away from you in Camino Ca - just east of Placerville - would like to borrow it if possible and would pay for postage.
Lee
We have 28764 guests and no members online
