TOPIC: Late 50's stand
Late 50's stand 12 years 9 months ago #89072
  • Seymour
  • Seymour's Avatar Topic Author
Not quite a Merc but close enough. My little project that is here today and on sighting tomorrow.
Picked this up last night and should have it refinished soon. I started with a media blaster then used aircraft stripper for that dang paint. Nasty stuff. The top peice is untouched and shows what shape the bottom was in when I got it. Tomorrow the bottom will get blasted again and I will hopefully get the top clean depending on how stubborn that paint is. Any tips or cheats anyone has encountered to get it cleaned up without damage? I am alway lookin for an easier way that does te job right.
Re:Late 50's stand 12 years 9 months ago #89076
Seymour,
Have you tried the electrolysis method. That works on paint sometimes too ?
I’ve had to soak a piece a few times before to get all the paint off.
Supplies needed:
Box of Arm & Hammer powdered laundry detergent
Rebar from home shopping center
Spring clamps or bucket lid/ barrel lid
Wire to connect rebar pieces in series
Old style battery charger (not the newer digital smart charger)
Plastic Bucket or barrel, plastic rectangle storage bin, even a cheap molded plastic kiddie pool works depending on part size ?
Water
Assembly:
Stand pieces of rebar and clamp rebar to inside perimeter of bucket, barrel, whatever (quantity of rebar ? 2 to 6 pieces…. In this case, more is better)
If you use a bucket, barrel, or storage container lid … drill holes on perimeter of lid to hold rebar up. Also cut as much of the center lid out for part to fit in and hydrogen gas to escape
Strip ends of wire and connect wire to rebar all the way around the bucket or container
Add water to vessel
Add Arm & Hammer laundry detergent, about a cup For 5 gallon bucket a whole bunch for 55 gallon barrel…. You really can’t over do it, but you can under do it, so more is better.
Hang part in water from a piece of rebar across the lid. I use wire coat hangers. DO NOT allow the part or rebar across the lid to touch the standing rebar around the inside of the container
VERY IMPORTANT STEP !!!!!
Hook the positive lead of the battery charger to the perimeter rebar that is wired together
Hook the negative lead of the battery charger to the part or cross rebar
The rebar is the sacrificial lamb, and will be eaten away in the process, while your part is de-rusted, and paint is loosened
If you hook the leads up wrong, you will not be happy. Because you will have rust free rebar and a disintegrated part
THE CAUTION:
This process releases Hydrogen gas (remember the Hindenburg ?) So do not do this in a confined space or basement, because you may find your house on the moon ?
The process:
As soon as you plug in the charger, the action starts immediately , and you will see little bubbles form around the hanger or part right at the water surface, the bubbles are the hydrogen gas released.
After an hour or so, there will probably be a scum layer of crap on top of the water that has come off the part (see page 3 of “Lake Shell Rebuild” in the Member Projects section cleaning a gas tank)
They say the bubbles stop once the part is clean, but that has never stopped for me ?
Once you pull the part out of the water, after you unhook the charger, the part will be black.
I then put a small wire cup wheel on a hand drill, and clean the black off
The beauty of this process is:
You can do other things, or sit back with a beer, while the part cooks AND this process gets into every nook and cranny that media blasting can’t get too.
If any of these instructions were un-clear ? There are many youtube videos to show the setup, and finished part. Just search for electrolysis rust removal.
Have fun !!!
Re:Late 50's stand 12 years 9 months ago #89246
  • Seymour
I stuck with the sand blasting but will try your method on some scrap to make sure I understand it. Trial and error was not an option for me on this particular peice. Only paint left and you can see the finished product.
Re:Late 50's stand 12 years 9 months ago #89247
  • Seymour
Didn't like the picture I added to te first one
Re:Late 50's stand 12 years 9 months ago #89287
I understand... I tried it on a test piece first time too.
Your stand looks awesome by the way
Re:Late 50's stand 12 years 8 months ago #89753
  • Seymour
The stand is complete with paint now came out better then I anticipated!!
Re:Late 50's stand 12 years 8 months ago #89754
  • Seymour
It will live indoors now on carpet in a very loving home. Good to see it in the hands of a careful collector
Re:Late 50's stand 12 years 8 months ago #89790
Great job. i need to get to mine. 3 merc stands and 1 chrysler.
Re:Late 50's stand 12 years 8 months ago #89807
  • Seymour
You poor soul all those stands!! Let me ease the burden and one can go to my house! I hope to find another when I am in more of a position to hold on to it. Ideally with a mark 55h hanging from it!
We have 27332 guests and one member online
