TOPIC: Gas leak upon Tilt
Gas leak upon Tilt 12 years 11 months ago #86394
I was fiddling about with the Merc yesterday and dropped a screw into the pan (wish I had a dollar for every time THAT happened). I order to find it I tilted the beast all the way up and gas leaked from the throat of the bottom carb in a thin but steady stream.
Normal? I hope not. What would be the cause?
Re:Gas leak upon Tilt 12 years 11 months ago #86398
Peter, it is completely normal. There is a vent hole in the fuel bowl that opens out to the carb throat just by the plastic venturi mounting slots. Fuel will run out of there when you tilt the engine.
Re:Gas leak upon Tilt 12 years 11 months ago #86405
Thanks Dave!
Re:Gas leak upon Tilt 12 years 11 months ago #86407
Whenever you pull boat out of the water it is a good idea to run the carburetors dry.
Re:Gas leak upon Tilt 12 years 11 months ago #86437
I always do - occurs to me with this writting that I was trying to start it a few weeks ago after having installed/set up new points and she wouldn't go. I had intended to try again the next day and that neaver happened. So tonight will open the bowls and empty them out as it may be a few more weeks before I am able to toy around with her again and I hate the idea of that alcohol sitting in the carbs.....
We have 25509 guests and no members online
