TOPIC: long or short shaft motor
long or short shaft motor 13 years 3 months ago #81143
I have a 1963 white and black mercury 500 with a long shaft. Is there a way to know if it will work or do I need a short shaft. The boat is a 1958 beeline boat. any help will be appreciated thanks
Re:long or short shaft motor 13 years 3 months ago #81152
Measure your transom, it should be 20 inches to the bottom of the boat for a long shaft, 15 inches for short shaft. A long on a 15 inch transom will push the boat, but it will drag like crazy. You can have the transom raised if necessary, but make sure the builder knows what he is doing first. Best thing would to find the correct length engine, your boat is probably a short shaft, 15 inch.
Re:long or short shaft motor 13 years 3 months ago #81208
I measured the boat transom and it is 17'' from top to bottom of boat. does this give me the option of either long or short shaft? please advise. thanks again
Re:long or short shaft motor 13 years 3 months ago #81209
It is a short shaft transom, and you will need a short shaft engine, sorry. Yours can be converted to a short if you can find a donor engine however.
Re:long or short shaft motor 13 years 3 months ago #81232
  • g3bill
  • g3bill's Avatar
Or you could mount a Jack Plate that will allow adjustment to proper height without messing with the transom.
3 cd g3's
1 seafair sedan
Re:long or short shaft motor 13 years 3 months ago #81400
Yes!
We have 12477 guests and no members online
