TOPIC: mercontrol removal
mercontrol removal 16 years 5 months ago #7779
I need some help removing a mercontrol.I already removed the set screw that holds the handle but when i tried to pull the handle off it slid out about an inch and something else is holding it.Do I need to remove the button in the middle of the handle first? If so how?I removed a plug on the back directly behind the button and the plug and a spring came out but it didn't help.any help would be appreciated
Re:mercontrol removal 16 years 5 months ago #7782
many different mercontrols. pics would help.
Re:mercontrol removal 16 years 5 months ago #7785
it,s for a 66 950ss thunderbolt on a 66 glasspar avalon trying to get pics now
Re:mercontrol removal 16 years 5 months ago #7787
Re:mercontrol removal 16 years 5 months ago #7806
button should unscrew first.
Re:mercontrol removal 16 years 5 months ago #7859
unscrew the whole button from the front?
Re:mercontrol removal 16 years 5 months ago #8203
  • 63g3
Black button unscrews, loosen set screw, then lever will come off.
I have a 66 950SS too! but with standard control box, not the hidden one.
Randy
Re:mercontrol removal 16 years 5 months ago #8233
Yes, the black button unscrews on the early MerControls. Later ones snap on and require a small screwdriver to pop them loose.
The set screw needs to be loosened which you did.
Re:mercontrol removal 16 years 4 months ago #8489
thanks guys!! It was easy just didn't want to break it I don't know why I didn't try unscrewing it :unsure:
We have 19753 guests and one member online
