TOPIC: Reverse lockout "thingy" - remove it?
Reverse lockout "thingy" - remove it? 14 years 5 months ago #61916
She's starting to look like a motor again. Test fitted the lower and tested the shift mechanism from the levers from the pan. So far so good
Next question; inside the mid section, in front of the shift shaft, there is a lever of sorts that is part of the reverse lock mechanism (which I think I have incorrectly been referring to as the reverse "lock out"). This shot is looking 'up' into the mid section.
I don't believe I need to worry about removing this lever. It will still rise and fall with shifting (by action of the reverse locking cams), but it shouldn't jam anything (I did re-install the white nylon spacer that goes under it).
Re: Reverse lockout "thingy" - remove it? 14 years 5 months ago #61919
no need to remove it just the rod and hooks.
Re:Reverse lockout "thingy" - remove it? 14 years 5 months ago #61920
  • g3jim
  • g3jim's Avatar
you do not need it. leave it or remove it your choice.
Re:Reverse lockout "thingy" - remove it? 14 years 5 months ago #61927
Thanks guys! I figured as much.
Tomorrow I remount the power head!
10-13-2026
We have 22180 guests and one member online
