TOPIC: Mercury 110 9.8 HP - 1971 - Won't Start
Mercury 110 9.8 HP - 1971 - Won't Start 14 years 7 months ago #58828
I have a merc 110 9.8 and can not get it to go.
So far:
1. I have some spark (I took it to a dealer and he indicated that it was not strong enough and needed a stator)
2. I got a new stator (was not cheap)
3. Still won't go
Cleaned the points
Cleaned and new seats in carb
Any suggestions?
I was also wondering what is the correct point gap
Re:Mercury 110 9.8 HP - 1971 - Won't Start 14 years 7 months ago #58846
Sounds like you have two bad stators.
Just kidding ( I was talking to you last night and referred you here :-)
I found this on another forum where a guy had a similar motor with weak spark issues.
That model has 2 white plastic insulating blocks that the points wire goes through at the bolt.These crack and can be very hard to see the cracks.(shows up more like carbon tracks)The voltage will track to ground from these, I would advise you to replace these anyway.Have seen alot of guys change stators and the only problem was the blocks.
Good luck,
Tim
Tim
\"Barnfinder\"
Re:Mercury 110 9.8 HP - 1971 - Won't Start 14 years 7 months ago #58864
I agree, most of the time the issues with that engine is the blocks, very common. I always use the choke to stop the engine on that model, the stop switch breaks the ground to the stator which can damage it from a voltage spike. Stators for those are worth a fortune at a Merc dealer.
Re:Mercury 110 9.8 HP - 1971 - Won't Start 14 years 7 months ago #58870
Tim, thanks for the great tip / I will give it a try
Re:Mercury 110 9.8 HP - 1971 - Won't Start 14 years 6 months ago #59080
Tim, I replaced the insulating blocks and I no improvement. I have a spare coil and this works in both locations. I have another on order. I think I replaced almost everything on the ignition system. I may have had a multiple of issues.
Thanks again.
Re:Mercury 110 9.8 HP - 1971 - Won't Start 14 years 6 months ago #59159
How are you making out Rick?
Tim
\"Barnfinder\"
Re:Mercury 110 9.8 HP - 1971 - Won't Start 14 years 6 months ago #59211
the coil is due to arrive Friday
Thanks Again
Re:Mercury 110 9.8 HP - 1971 - Won't Start 14 years 6 months ago #59336
Did get ti running - thanks
Re:Mercury 110 9.8 HP - 1971 - Won't Start 14 years 6 months ago #59391
Damn electrical issues....funny how coils can work "a little bit" isn't it.
Glad to hear you got it figured out.
Tim
Tim
\"Barnfinder\"
We have 12362 guests and no members online
