TOPIC: Dyna Float (Lower Mount) Installation
Dyna Float (Lower Mount) Installation 14 years 8 months ago #56651
Starting the reassembly of the 1000.
Rebuilt the motor stand that I've been using for sometime so that it leans back at the same angle as the transom of the boat, so that the motor can be oriented straight up (vs pitched forward when in the full down position when the stand was straight). That was a nice hour distraction from the day's responsibilities.
So the first thing to go back on is the mid section.
The question: Is there anything I need to do to the lower mount assembly before installing it? Lubricate the entire thing with fogging oil or some such?
The Modified stand (I know, who cares really). Hard to see in this picture with all the crap in the back ground
The lower mount set in the mid section.
The cleaned up mounting assembly
Re:Dyna Float (Lower Mount) Installation 14 years 8 months ago #56698
yes lube with grease . you may have to remove at a latter date. lube every thing including bolts and nuts.
Re:Dyna Float (Lower Mount) Installation 14 years 8 months ago #56708
I figured as much. Any heavy greese or do I need a Marine greese (just what is the difference between Marine greese and standard heavy greese)?
Re:Dyna Float (Lower Mount) Installation 14 years 8 months ago #56718
Never mind. Found my big ol' tube of Mercury Multi-Purpose Marine Greese
Re:Dyna Float (Lower Mount) Installation 14 years 8 months ago #56725
That's IT !
10-13-2026
We have 22086 guests and no members online
