TOPIC: Question about control cables
Question about control cables 15 years 1 month ago #44300
  • oldboater
  • oldboater's Avatar Topic Author
I need to buy some new control cables fo my '69 800
I've looked at the 600a cables, and they will work. But I saw some similar cables called Gen1. Are Gen1 cables just an up grade of the 600a? I also have one tight bend to make would these work better?Opinons Please :)
Re:Question about control cables 15 years 1 month ago #44303
  • 65G3
  • 65G3's Avatar
I installed the Teleflex cables on my 78 merc. 70 hp they work fine !! about 60.00 bucks Check around for prices
Re:Question about control cables 15 years 1 month ago #44307
Some member/owner here probably has cables in the store room they don't need.
Jim Savage
Re:Question about control cables 15 years 1 month ago #44336
Oldboater,
I have a LOT of good used and some NOS control cables that will work on the '69 800 4cyl with the square black single lever control box.
If you have a sharp corner to bend the control calbes through perhaps we can discuss it and find a better way to route the cables to avoid that problem.
Write direct if you are interested.
frankenmerc at comcast dot net
Thom
Re:Question about control cables 15 years 1 month ago #44410
  • oldboater
Thanks for the reply Guys!
Doc, I might need to take you up on that offer.
So, this is what I think I know, :P
The Teleflex 600A series, TEL-CC179 is compatible with my control box and motor.
What I'm not too sure about are these so called premium cables.
Quicksilver 897977A15 cable T/S-Premium-GEN 1
or
Teleflex TfXtreme CCX179 Premium Control Cable
Do you guys think either of these would work as a direct replacement?
Can they make tighter bends?
Anyone had any experience with either of these?
Are they worth the extra money?
Thanks again for the help!
10-13-2026
We have 23627 guests and one member online
