TOPIC: Power Head swap Merc 500 1970 and 1972
Power Head swap Merc 500 1970 and 1972 15 years 2 months ago #42997
  • stashm2
  • stashm2's Avatar Topic Author
Hello,
I have a 1970 Merc 500 Red stripe with a bad piston and a good mid and lower, and a 1972 blue stripe with a great power head but a very corroded mid and lower. I would like to know if these two powerheads are interchangable or if there is a difference in the exaust ports ect.
Thanks.
Jesse
Re: Power Head swap Merc 500 1970 and 1972 15 years 2 months ago #43012
i think the are.
Re: Power Head swap Merc 500 1970 and 1972 15 years 2 months ago #43016
  • stashm2
Looking at parts lists etc. It looks liek they should I guess I will find out :-)
Re: Power Head swap Merc 500 1970 and 1972 15 years 2 months ago #43037
Jesse,
If you make the swap at the gasket between the powerhead and the exhaust extension plate you will be fine.
That gasket is Mercury Marine part number 27-796501 or through your local NAPA it would be Sierra Marine Part number 18-0103.
Be aware though - that if you attempt to swap out the lower unit off one to the other it 'might not' work - but if things above the gasket mentioned are kept togehter from the same year and things below the gasket are kept together from a different year - what you want to do will work.
Doc F
Re: Power Head swap Merc 500 1970 and 1972 15 years 2 months ago #43064
Hey Doc, Good to see you here!!! Joe
Re: Power Head swap Merc 500 1970 and 1972 15 years 2 months ago #43130
  • stashm2
Doc. Thats exactly what I wanted to know and plan to do! Thank you all for the info!
We have 26728 guests and no members online
