TOPIC: L/U Oil
L/U Oil 15 years 6 months ago #30475
  • joenawlins
  • joenawlins's Avatar Topic Author
Can't find my pocket guide. What weight oil for L/U ? tHX
Re:L/U Oil 15 years 6 months ago #30477
What year and hp motor Joe?
Re:L/U Oil 15 years 6 months ago #30478
  • joenawlins
mark78
Re:L/U Oil 15 years 6 months ago #30482
They actually use grease.....Lubriplate 105. www.lubriplate.com/webstore/detail.aspx?ID=17
But I have used the Lucas 140w. That lower needs a high pressure lubricant. DO NOT USE A MULTI GRADE 90W!!!!!!
Re:L/U Oil 15 years 6 months ago #30483
Marathon6 speeks well I use the heavier 140 oil in mine. Grease is good if you have leaks thoo...
Conrad
Re:L/U Oil 15 years 6 months ago #30508
  • joenawlins
Thx All, I didn't have water in my L/U. That lucas 140 looks like what came out. Put it back together and ran w/o prop and still fires up with a tap of the starter button. Still sounds like it's mis firing, more at idle it seems and rougher in reverse. Pulled and gapped plugs and they looked good. They have NGK88s i think and book says J6J. Is that ok? Thx,Joe
Re:L/U Oil 15 years 6 months ago #30509
UMMM... Did you give us an update on what you found inside that case before you buttoned it back together?
I thought you had some noises/ drive shaft play??
Conrad
Re:L/U Oil 15 years 6 months ago #30511
  • joenawlins
It was min play and I cleaned it up and put it back together and it's not making any noise. Don't ask me, there is no noise now and it's running cool.?????? Joe
Re:L/U Oil 15 years 6 months ago #30515
Sometimes its good to have no problems:)
J6J should be a B6S NGK
You sure you didnt read B8s NGK? Id get B6s's NGK's or J6J's
Conrad
Re:L/U Oil 15 years 6 months ago #30516
  • joenawlins
Not sure, have to look in am. Joe
Re:L/U Oil 15 years 6 months ago #30552
From what I saw in the photos Joe...you are definately getting water in your oil! When you say "little play" how much? As I said before, lash adjustment is only .005". That lower needs a tear down....but, it's your motor....
10-13-2026
We have 24730 guests and no members online
