TOPIC: Merc 400 water pump impeller-no flow
Merc 400 water pump impeller-no flow 15 years 6 months ago #29681
Hello I am looking for some help on a 1960 merc 400
My concern is with the water pump impeller. It seems that the impeller with it's little pin that fits in the tapered groove in the shaft is designed to catch and spin the impeller in only one direction. Problem is the direction the motor turns with the pull starter and the electric starter with negative ground is opposite to the direction the impeller needs to spin to catch and rotate. So my question is could there be a mismatch with the lower unit and power head. I see their is some reference to standard and counter rotation. Could someone clear this up for me, even a phone number would help. Thank you Scott
Re: Merc 400 water pump impeller-no flow 15 years 6 months ago #29682
call me 1 914 310 7086. Dave.
Re:Merc 400 water pump impeller-no flow 15 years 6 months ago #29701
Thanks Dave :)
Re:Merc 400 water pump impeller-no flow 15 years 6 months ago #29714
Thanks Dave :)
We have 21682 guests and no members online
