TOPIC: Oil Leak
Oil Leak 15 years 7 months ago #28147
  • joenawlins
  • joenawlins's Avatar Topic Author
I brought my Owens home and after a day significant oil leaking out of the weep hole on the left side of my Mark78??? I have a feeling that's not normal??
Re: Oil Leak 15 years 7 months ago #28150
i would say it is unburnt fuel. check the lower unit for water that will tell you.
Re: Oil Leak 15 years 7 months ago #28152
  • joenawlins
I run it out of fuel after each run, but will check the L/U in the am thx
Re:Oil Leak 15 years 7 months ago #28155
2 strokes, by design, blow a small amount of fuel out the exhaust during scavenging. The gas vaporizes, the oil remains and passes down the leg, some seeps out the hole you seen. Normal.
Re:Oil Leak 15 years 7 months ago #28163
I use a white plastic "test barrel", it will amaze you how much oil residue is left after running one for 15-30 minutes!
Re:Oil Leak 15 years 7 months ago #28165
  • joenawlins
I did that the first time I ran it at friends house and the trash can was full of oil as I remember. Thx all, feel a little better. BTW I found a gas station near the marina that sells no ethanol gas!!! Love it.
Re:Oil Leak 15 years 7 months ago #28170
Yep completely normal and really hard to keep white paint looking good with it oozing all over the place. You wipe it down after a run and an hour later you have a dark run mark over you beautiful paint.
Another good reason for the change to Black by mercury. It hides the oil stains better :)
Conrad
Re:Oil Leak 15 years 7 months ago #28176
  • joenawlins
LOL Makes sense.
Re:Oil Leak 15 years 7 months ago #28227
Joe,
Can you post a better picture of what you're calling a weep hole?
Your red arrow looks like it is pointed at a round hole that should have threads in it and a plug - if it is the hole my blurry old eyes think you're pointing at.
Thom
:P
Re:Oil Leak 15 years 7 months ago #28237
  • joenawlins
Hey Thom, It's a pin hole about an in.3/4 fwd of the flush port. Thx Joe
Re:Oil Leak 15 years 7 months ago #28249
Just a thought on using a small barrel for test runs and flushing, any 2 stroke. Aren't you running that oil back through the inside of the water jacket? Any bad effects from that?
old darb
Re:Oil Leak 15 years 7 months ago #28251
nope that is how it is done at the dealers when a motor comss in off of a boat.
Re:Oil Leak 15 years 7 months ago #28262
Oil should not hurt the cooling passages. Plus your water pump usually pulls water from the bottom of the barrel that is cleaner. Oil usually sits on the top of the water and clings to everything when you pull your motor out.
Conrad
10-13-2026
We have 21161 guests and no members online
