TOPIC: Shift shaft measurement for a long shaft 15 HP
Shift shaft measurement for a long shaft 15 HP 11 years 1 month ago #115106
I don't have a manual for this little Merc. It is a long shaft 15 HP, about a 1990ish. Serial number 0C222----
I know I have the serial number on my desk,...SOMEWHERE,...But current 'digs' have not located it.
I need to know the length that a long shaft lower shift shaft needs to measure to be accurate for shifting after assembly.
doc F
Re: Shift shaft measurement for a long shaft 15 HP 11 years 1 month ago #115109
  • Thank you received: 131
Hi, Doc, for a long shaft motor, 22 inches measured from the top of the water pump base to the center of the shift shaft hole.
Found that info in the online Merc service manuals at www.Boatinfo.no .
www.boatinfo.no/lib/mercury/manuals/6-8-99-10-15.html#/216
Note that the previous page has you shifting to Neutral before checking the shift shaft length.
Hope that helps, have fun in the shop!.......ed
p.s. if the link doesn't take you right to the page, it's page 217 of the file, or page 6-34 of the manual.
Re: Shift shaft measurement for a long shaft 15 HP 11 years 1 month ago #115129
Thanks Ed!
doc
We have 11060 guests and no members online
