TOPIC: 1963 Starcraft 14' Ranger Project
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #59949
  • littlefin
  • littlefin's Avatar Topic Author
More Pics
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #59951
  • littlefin
More Pics.
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #59953
  • Neil
  • Neil's Avatar
Looks like you are on your way, it is going to be a nice one.
Neil
Neil and Mary Ousnamer
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #60031
Ive allways liked these boats, I grew up on a small lake in N central IN, and even later in Florida I had several of these. though mostly powerd by 35-40hp omc I had 1 with a Flying Scott 75hp that ran in the mid 40s. have fun with this,Oh and what a cool engine, a short shaft johnson,very rare. Whats the hp on that? 55-60?
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #60035
  • littlefin
Thanks, 1969 Johnson 55hp Commercial.
I've been out sanding down the crazing and gel-coat. Just about ready to apply the filler, as soon as the temps get into the 60's.
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #60064
Hi Littlefin Nice project i just strted sanding my 14' Arrow looks similar to yours , It says the weight is 495lbs on mine , I was wondering how you flipped yours upside down I need to do the same thing but im not that strong lol .
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #60091
  • littlefin
Dart,
The Arrow is the sister to the Ranger (Econo-Models).
I laid a tarp out on the yard and rolled it sideways to get it upside down. Then four of us, lifted it on two a couple of cinder blocks, with a 2x6 going cross. None of us are as young or strong as we used to be, but it wasn't bad to lift.
P.S. Thats one nice lookin boat ya got there friend!
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #60099
Sometimes you gotta get creative, Dart! I used a come-a-long on the bow eye and an engine hoist with a socket extension thru the splashwell drain to flip mine;
www.fiberglassics.com/glassic-forums/29-member-projects/31614-new-project-71-glastron-gt-150.html?limit=40&start=40
I see some trees in the pic of your Arrow (good looking boat, btw), any big limbs nearby? :)
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #61131
  • littlefin
If you don't know how to use filler,.....You will learn fast!
Mix, Apply, Sand all of it off, and try again. REPEAT!!!!
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #61132
  • littlefin
As for the 69 Johnson 55 hp. Well we did some wiring. Then replace impeller and some seals. Sanded down the ICKY white stuff, and sprayed some sealer on it.
Its probably not worth the effort (or money) to fix it, but I want to at lest try it out before I trash can it. If it works well enough then it will get the treatment later.
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #61158
  • littlefin
Finally a coat of GEL. Man do I suck at this. I thought the gel-coat would cover up some of the pin-holes and small scratches, but once again I am WRONG.
Remember kids ANYTHING you can see or feel WILL show up after the gel-coat. If you want it to go away you have to work harder at it.
P.S. Gel-coating with a roller and brush in direct sun light is a NO-NO..... Live and learn. Its only money and time.
Here's the proof. NO I'm not a proud boat owner. SHAME on me.
WANTED: Any extra Gel-Coat and Sand-paper I can get my hands on.
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #61212
  • littlefin
Good news I noticed this morning that the Gel-coat is starting to flatten out. The really bad areas are looking a heck of a lot better.
My spirits are much better after seeing this.....so back online to order more Gel-coat. Never give up....NEVER!
Re:1963 Starcraft 14' Ranger Project 14 years 6 months ago #61223
  • Andgott
  • Andgott's Avatar
Yeah, I've been there- With paint, not Gel-, but it's the same principle. EVERYTHING has to be perfect, or it will show up later... Those little pin holes, minor scratches, etc that you think at going to fill just don't, and tend to look worse in the process!
Gel is a pain, but forgiving. Sand, Sand, sand- And it will be smooth, shiny, and look like new!
-Andrew
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #61330
when you get done with this lil boat....you WILL know somthing about sanding-gelcoat-sanding-did I mention sanding?....lol, keep going you will get there!
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #61529
  • littlefin
It's 85 degrees out no wind, and NO RAIN in sight! Looks to be a perfect time to apply another coat of Gel-Coat to the Starcraft.
Mix it up, brush it on. Step back. Admire my work. Then NEEEERTTT!
NEEERRRTT! The NOEL Weather Station in Duluth is under a Sever Weather Alert. Strong winds, hail, and heavy rain, are due in the area with in the hour.
WHAT????? Panic sets in. Run in the garage and grab the step ladder and dolly. Slip old conduit together to make a long pole. DUCK TAPE it to the ladder and dolly. Scream to the wife COME HELP!!!
Toss the tarp over it and clamp everything I can down. The temp drops to 65 degrees in 20 min. The skies turn UGLY!!! Please let the Gel-Coat set up enough so the tarp doesn't stick to the boat. Winds start to pick up a lot. Please, Please let the Gel-Coat hold up.
Scary Stuff!
15 Min. before
Man Lake Superior can suck at times.
Stay Tuned!!!
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62037
  • littlefin
Made it through the storms, no damage to anything YEAH!!
Found a trailer locally for $100. Not perfect, but not to bad.
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62042
AAAAH Ya...midwest weather. dont like it,wait 5 min itl change! Im in the indy area.
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62217
  • littlefin
The start of the final polish on the Gel-coat for the bottom before flipping. Once again not perfect, but a heck of a lot better than it was.
CLICK ON THE PICS FOR FULL EFFECT!!
Before
After
Now I have to get fixin on the trailer so I can finely move it around. I'm like a kid at Christmas. I just can't wait to start on the upper parts. Those are the parts that people can see what you have done.
Never give up, NEVER.
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62223
Looks good Littlefin, keep on rockin' buddy!
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62230
  • littlefin
Thanks Mark. One day at a time.
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62239
The work you have done on your hull looks just great. Believe me I have seen alot worse and I have done It really bad myself the first few times I tryed to do what you are doing. You have done well with all the crappy weather and such. You will end up with a fine looking boat when you get done. Keep up the good work, Skip.
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62279
  • Ritchie
  • Ritchie's Avatar
Looking really good Littlefin.
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62288
  • littlefin
Thanks guys. The encouragement is nice to have.
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62391
Great work and coming along at a good clip. Pray that is won't snow the next few weeks. I have a sister in law up in Bovey where the ice never gets off the lake until June.
Keep us posted.
cal
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62571
  • littlefin
Starcraft date 06/04/12
The flipping fairies showed up!!!!!!
Not quite as nice as WaterWings. But once its underwater.......
Before the fairies:
After:
Thanks to Dan, Felicia, Cheryl & Don, and Heidi, The Flipping Crew
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62581
Congrats on the "milestone" Littlefin, that's gotta pump you up !!! :P
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62582
  • Neil
  • Neil's Avatar
Looking good. Those "flippin' fairies" will be needing a ride in a boat soon!
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62589
Nice lookin' crew. Put oars in their hands and you won't need a motor. Another page in the book complete. You got it right, all trailers are equal once they are under water. It's the dogone sitting in the parking lot that somehow makes 'em look rusty.
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62609
She's looking GREAT!!!!!!!!!!!!!! Good looking crew by the way. The trailer looks great. Gotta love Black, it hides everything. Wished I could have gone black with mine but I wanted to stay true to it's original color, hence the white and then sand beige for the fenders and a few other parts
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62613
  • littlefin
Pumped up is right! I got the trailer adjusted to the boat, and started to wash it down. Once you get some of the moss and dirt cleaned away it starts to make you feel that this is do-able.
By the way those Flipin Fairies in the picture, the youngest one is graduating tomorrow. As for the other two, she's been married for two years, and the boy, well, he got stationed in Hawaii (Tough Tour).
But even so they all are waiting to go for a ride in the "NEW" boat. Along with the oldest (not pictured) and their three son's.
Wow! Four kids, two son-in-laws, three grand-children, and a wife. MAN! I think I might need a bigger boat. Oh-well better get this one done so I can start shopping for another.
Do you think the Queen Mary is considered a classic?
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62618
NO NO Noooo,Don't get a bigger boat! You need to get another smaller one that needs an entire makeover. Two is better than one, besides what would you do with all the spare time when you close the book on this one?
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62642
  • littlefin
Like maybe a boat a piece?
A Flotilla?
My very own Armada?
Oh just think about it!!
We could take over the world!!!
Or maybe just one of the slips at the marina then.
Re:1963 Starcraft 14' Ranger Project 14 years 5 months ago #62653
littlefin,its looking great,get another one to do.
and take over the world,lol,lol,
Re:1963 Starcraft 14' Ranger Project 14 years 4 months ago #63101
  • littlefin
Just a quick up-date on my progress.
I still hate sanding.
I still hate buffing.
Stay tuned for more up-dates!
Re:1963 Starcraft 14' Ranger Project 14 years 4 months ago #63105
  • frog
  • frog's Avatar
  • Thank you received: 3
littlefin, very nice looking boat. i was thinking about you and was hoping the flood did not wash you into the big lake. aitkin county was just about under water wed. take care and you will get to like sanding. lol. frog
Re:1963 Starcraft 14' Ranger Project 14 years 4 months ago #63109
  • littlefin
Thanks Frog!
We survived the flood with only a small amount of water in the basement. I feel very fortunate, many others didn't fair as well. It will be a very large undertaking to clean up this mess, and fix the roads and homes that were destroyed and damaged during the storm.
I have been blessed with Gods kindness once again. Remember to never take any day for granted.
Even the ones spent sanding and buffing!!!!
Never give up.....Never.
Re:1963 Starcraft 14' Ranger Project 14 years 4 months ago #63121
Got a call from my sister in law up in Bovey, Hartley Lake. She was in Duluth during the storms and saw the damage, said she headed north when it got really bad. Count you blessings my friend.
Cal
Re:1963 Starcraft 14' Ranger Project 14 years 4 months ago #63165
  • littlefin
Cal,
I'm glad to hear she got out of town in time. I hope her home was okay.
Re:1963 Starcraft 14' Ranger Project 14 years 4 months ago #63385
  • littlefin
Update:
Mounted up my 1969 Johnson 55hp Electric Shift. I tipped it up and stuck the scag in the soft dirt and had my wife balance it as I tipped the boat up and backed it up to the motor.
Fit right up to the holes right away. No little blonde girls where hurt in the making of this boat (YET).
I got everything connected the next night. Then borrowed my neighbors water muffs and fired it up. It started up in about two revolutions and ran like new.
I couldn't get it to shift, but I found that I had a bad vacuum switch that sends power to the shift solenoids in the lower unit. Ordered up a new one, and its on its way.
I next bypassed the switch and found it still wouldn't shift, it just stays in forward default mode. Then I tested the wires for current and all was good. Then I tested the solenoids and they checked out good. Now I was just a little confused.
Went back in and read the repair manual again. Now it tells me I might have not lined up the rods in the solenoids right. DANG IT!! Now I have to pull the lower unit of again (3rd time) and reset them.
Well this time I think I will try and do it blind folded, that way if it still doesn't work I will have a better excuse as to why.
Stay tuned kids....... This could get ugly.
P.S. If this Johnny doesn't start behaving soon I might have to send it to Uncle Neil's, so he can use it for target practice.
Re:1963 Starcraft 14' Ranger Project 14 years 4 months ago #63388
  • Neil
  • Neil's Avatar
[Never give up...Never.] I read that somewhere!!
Hang in there, it is just a machine. She is going to run like the wind and shift perfect.
Neil
Time to create page: 0.145 seconds
We have 7049 guests and no members online
