TOPIC: Electric Ignition Conversion Problem
Electric Ignition Conversion Problem 11 years 9 months ago #83611
Had a great time at the Buffalo Boat Show...even though it rained. Met some great people from FB! So, I was advised to change over my distributor to a electric ignition system. So today, I installed the Hot-Spark system and a new 3 ohm coil for my 1961 Volvo Penta BB70 engine. It turned over many times, but after a few revolutions, it would just give out a "spit". Can this engine be adjusted in the timing? is this something I have to do? Could it be another problem?
Dreams do become reality!
Re: Electric Ignition Conversion Problem 11 years 9 months ago #83635
any takers?
Re:Electric Ignition Conversion Problem 11 years 9 months ago #83636
Sorry, I'm not familiar with the Hot Spark systems.
I did find this you might find helpful however;
www.hot-spark.com/Troubleshooting.pdf
Re:Electric Ignition Conversion Problem 11 years 9 months ago #83650
got it running...had the distributor 180 Degrees backward. Runs, but very "chuggy". Will need to get a timing light but I think I can adjust it by the sound. What do you all think?
Re:Electric Ignition Conversion Problem 11 years 9 months ago #83657
Many of the auto parts stores rent tools (like timing lights), I think I'd want it set to specs personally. You could probably get it close "tuning by ear", but too little timing will waste fuel and be short on power - to much could damage the engine with detonation. With the conversion kit you would only have to set it one time, should be good to go after that!
Just my two cents worth.....;)
1964 Dorsett San Juan
We have 8906 guests and 3 members online
