TOPIC: engine stall problem
engine stall problem 11 years 9 months ago #83068
was out on the lake at the beginning of the season and then yesterday. (have a 10 week old son, so didn't get out much this year.) At low RPMs it does just fine, but when I get up to plane, it cuts out or "hiccups". Thought it was a fuel problem, so I changed part of the lines, but am still having the same problem. Could it be electrical? Would changing the plug wires be a solution? My engine is a '61 Volvo Penta BB70. The oil pressure seems fine. I think it only happens when the outdrive is engaged. I don't like to run the outdrive out of the water, but i may try it this morning. Well, anyone have ideas?
Dreams do become reality!
Re: engine stall problem 11 years 9 months ago #83078
That is a rare(?) motor is it not?
If someone here can't help, try the marineengine.com forums.
If it is that old and all the fuel lines haven't been changed, it is time.
Re:engine stall problem 11 years 9 months ago #83082
I have a 1962 Volvo Penta B18 AQ100 engine and had a similar problem. I took out the old fuel pump and replaced with a electric and a fuel pressure selector and gauge. Probable could have just replaced the old mechanical pump but this worked well and they were parts I had laying around the shop..
Re:engine stall problem 11 years 9 months ago #83084
tdavis 193,
WELCOME ABOARD.
(Sounds like a good plan to me.)
Re:engine stall problem 11 years 9 months ago #83111
  • Nautilus
  • Nautilus's Avatar
  • Thank you received: 58
I once had a similar problem and the cause turned out to be mud dobbers had plugged the fuel tank vent. I discovered it when I left the fill cap off and it suddenly ran great. Worth checking?
Mentor to the unenlightened!
"Success makes...
Re:engine stall problem/FIXED! 11 years 9 months ago #83171
Aha! I cleaned the carb and then the fuel filter. After this, I checked the electrical wiring, and what do you know...the nut on top of the ignition coil was very loose. Tightened it up and took the boat out on Lake Chautauqua where we are vacationing right now. Spent over an hour cruising without one incident!!! Looking forward to the show in Long Island on Saturday! Thanks for the help guys!
Re:engine stall problem/FIXED! 11 years 9 months ago #83192
  • Mr. 88
I hope you mean Grand Island as Long Island is 7 hours in the other direction.Glad you found and fixed your problem.
cool runnings Mr 88
1964 Dorsett San Juan
We have 7107 guests and one member online
