TOPIC: Problem solved: Suzuki DT50
Problem solved: Suzuki DT50 12 years 1 month ago #77363
  • Don D.
I recently restored the 1975 CacciCraft and mounted a 1984 Suzuki DT50. I ran it for the first time a few weeks ago and it would plane out the boat, but very sluggish. I thought it was a prop issue and tried several different props with very little change in performance. It turns out I was running on 1 cylinder. The CDI unit was bad. I installed a new CDI and ran it yesterday and it is super fast now. I guess I should have checked both cylinders for fire, but it ran smooth with no vibration or miss. I would have thought a twin cylinder running on 1 would be very easy to tell, but apparently Suzuki makes a perfectly balanced engine.
Regards, Don
Re:Problem solved: Suzuki DT50 12 years 1 month ago #77365
Glad you got it sorted out Don. ;)
Re:Problem solved: Suzuki DT50 12 years 1 month ago #77368
I have a Honda and the worst thing I found out about newer outboards is the sensitivity to the ethanol in the gas. Still got that cable soaking in oil. Been busy so I hope it has worked it was around. I quess you'll have to make another vid.
Re: Problem solved: Suzuki DT50 12 years 1 month ago #77369
Don,
Was that a CDI off of the DT50 you got from me? The river is really high today, I went to Ancarrow's Landing and it was up over the sidewalks. I may try another ramp further down river to test the McKee craft.
Hello, World!!
Re: Problem solved: Suzuki DT50 12 years 1 month ago #77382
  • Don D.
Ken, The DT50 I got from you turned out to be a 1981. The CDI on that motor has a totally different wiring harness. The price for a new CDI was $379 (ouch!!) but I found a NOS one down in Florida for $149. I ran it last night at Lake Chesdin. It is a screamer now that its running on both cylinders. I mounted 4 rod holders and will be putting in a CD player today. I spent the first 4 hours this morning replacing all 3 belts on my mower. Had to completely remove the deck to get to them. What a pain. I'll make a new video running the boat soon.
TTYL, Don (Jay)
Re: Problem solved: Suzuki DT50 12 years 1 month ago #77431
It's amazing what you can do with some elbow grease and some determination.
After some chores I cleaned the Glastron and McKee craft but the James river had flooded and there was alot of logs, debris in the water. Ancarrow's Landing was under water.
Where do you put in at Lake Chesdin? I may try that some time.
I hope you try getting that 81 started: would like to see if you have any luck with it!
Hello, World!!
Re: Problem solved: Suzuki DT50 12 years 1 month ago #77481
  • Don D.
Ken, I usually launch on the Dinwiddie side at the public boat landing by the dam (free). Another good place is Seven Springs Marina on Chesterfield side ($7). The lake offers some decent fishing for bass, crappie, perch, catfish ect....It does get choppy and congested during the peak times during summer on weekends. Any day Mon- Fri is decent.
1964 Dorsett San Juan
We have 9418 guests and no members online
