TOPIC: Help? How to adjust my Mercontrols
Help? How to adjust my Mercontrols 13 years 7 months ago #64263
I have a 1970's Mercury 500 50HP outboard with Mercontrols. It seems like there is a lot of play in the controls. When i put it in foward, it goes almost to the 10 o'clock postition before it starts to throttle up. Any help would be greatly appreciated. I hate only being able to go 5 MPH up the river.
Re:Help? How to adjust my Mercontrols 13 years 7 months ago #64265
check to see if the butterflies are opening in the carbs throat
is this motor and controls new to you, did you make any adjustment, since last used, etc etc
Re:Help? How to adjust my Mercontrols 13 years 7 months ago #64267
The motor and controls are new to me. I havent made any adjustments since the last time i took it out. I replaced the water pump impeller when I first bought it, took it out once and had these issues, then I drained and replaced the gear lube. I took it out one more time to see if it might have just been a binding-up in gears problem, but i had the same issues.
Re:Help? How to adjust my Mercontrols 13 years 7 months ago #64269
disconnect the cables from the motor....test the cables for unrestricted movement, then check to see if the butterflies are opening on the carbs before you reinstall the shift and throttle cables
this wil help determine where the issue is
We have 8498 guests and 2 members online
