TOPIC: Let's talk painting strategy
Let's talk painting strategy 13 years 8 months ago #62094
The sanding is finished on my Hydrodyne and now it's time to get serious about painting. Remember, I have removed all the gelcoat on the deck and will just be roughing up the hull. So, here is the plan:
For the deck~ 1 skim coat of West System Epoxy Resin; then application of same resin with 407 Low Density Filler for Filling and Fairing; then Interlux Pre-Kote Primer (2 coats sanded in between with 320 grit and wiped down with acetone. After final coat, sand with 400 grit and wipe down with acetone.); 3 coats Interlux Black Brightside Paint.
For the Hull~ Sand with 180 grit and wipe down with acetone; Fill and fair with West System Epoxy Resin mixed with 407 Low Density Filler; 2 coats of Interlux Pre-Kote Primer (same proceedure as for the deck); 3 Coats White Brightside Paint.
For the Outdrive~ Sand to bare metal; One coat Surface Primer Interlux InterProtects 2000E; 2 Coats Interlux Primer Primocon Aerosol; 3 Coats Interlux Antifouling Trilux 33 Aerosol.
The boat will be trailered and mostly used on the weekends. So from my research, the Interlux Brightsides should be fine. However, should I upgrade from the Pre-kote primer to the Primekote? Any thoughts are appreciated!
Dreams do become reality!
Re: Let's talk painting strategy 13 years 8 months ago #62097
  • Andgott
  • Andgott's Avatar
How do you plan to apply the paint? Are you spraying or rolling?
You are going through a LOT of prep work, and brightsides will work OK, but I'd really consider a more durable paint if I were you. Brightsides is pretty soft, and doesn't retain gloss as long as some other options do. There are a number of really nice multi-part paints out there that offer far more durability, and would not be that much tougher to apply. I just did my Lake N Sea with a 2 part urethane, and LOVE the results.
I used a single part called Supermarine Revolution on my Glasspar, and liked it a lot as well. It gets a lot harder than brightsides, and can be cut & buffed to an unreal shine. I sprayed, but you can roll and tip as well, it's just more work.
We have 12017 guests and 2 members online
