TOPIC: Boat Detailing
Boat Detailing 16 years 4 months ago #5416
Re:Boat Detailing 16 years 4 months ago #5434
This posting has been flagged for removal
Re:Boat Detailing 16 years 4 months ago #5438
Re:Boat Detailing 16 years 4 months ago #5454
  • bogman
  • bogman's Avatar
Interesting read, thanks for posting...
Re:Boat Detailing 16 years 4 months ago #5463
  • Heather
  • Heather's Avatar
Mrs Spookeay Bird
Re:Boat Detailing 16 years 4 months ago #5469
I believe the saying is "Often imitated, never duplicated"! ;)
Re:Boat Detailing 16 years 4 months ago #5500
Good topic for this time of year!
I found a couple of articles to add to the mix
This one is about how to diagnose gelcoat condition
ezinearticles.com/?Boat-Detailing---Diagnosing-Gel-Coat-Surfaces&id=25183
This is Meguiars Marine Guide in PDF
marinerv.meguiars.com/downloads/MaintenanceGuide_Marine.pdf
Peter
We're expecting snow
in Denver
Re:Boat Detailing 16 years 4 months ago #5504
  • Bigfoot
  • Bigfoot's Avatar
That cl ad will be gone eventually so here it is for future reading....
Begin>>>>>>
The Truth About Boat Detailing
Date: 2010-04-27
The following is a tutorial about boat detailing done right. I've been a professional boat detailer for over fifteen years and every Spring I see the same thing: Guys who spent a few months learning how to detail cars decide they want to start detailing boats too. Usually they do more harm than good. If your interested in hiring a detailer for your boat, please read this whole ad. At least then you'll be able to tell the professionals from the hacks.
The truth is, boat detailing and automotive detailing have very little in common with each other. The end result for both is a visually-appealing layer of protection, but that is where the similarities begin and end.
Most (fiberglass) boats are built the same way. First, a female mold of the boat is sprayed with catalyzed, air-inhibited gelcoat. Air inhibited means the gelcoat won't fully cure when exposed to air. This is done to aid the boat builder. Once the gelcoat has “kicked”, the surface will remain slightly tacky, this provides a good mating surface for the first layer of fiberglass. The boat is then built from the outside-in with successive layers of fiberglass. When the fiberglass is the appropriate thickness, the boat is popped out of the mold and, voila! You have a boat (or hull, or deck, or whatever).
The nuances of boat detailing I referred to in the first paragraph deals specifically with the gelcoat and how to protect it. Most people think gelcoat is as maintenance-free as the fiberglass itself. The opposite it true, gelcoat requires more ongoing maintenance that any other element of a fiberglass boat. The reason it is ubiquitous in the boating world is not because it's a superior finish for boats, but simply because it makes boat-building easier. The truth is gelcoat is committing a slow suicide beginning the day it's popped out of the mold.
Nothing is as damaging to your boat's gelcoat as UV exposure. As gelcoat ages and degrades, it becomes porous and chalky. Run your hand alongside any unprotected boat and you will see your palm turn white from the dead layer of gelcoat. The porosity, which looks like microscopic pinholes has a cumulative effect of reducing the overall gloss, even when buffed out. The result of both the porosity and the chalkiness creates a surface that degrades faster and faster as time goes by.
How NOT to protect it.
Any detailer who shows up at your boat armed with aggressive rubbing compound and a jug of cleaner/wax should be immediatley fired (and frankly, flogged). This person is about to vandalize your boat. Unfortunately, this usually goes unnoticed by the boat owner because the end result looks quite nice; the boat is shiny and water appears to bead up on the surface.
The problem with my fictional detailer is two-fold. First, aggressive rubbing compounds (in almost every case) remove far too much gelcoat to achieve a proper gloss. Because the gelcoat is only 20-30 mils thick (about the same thickness as 4-6 sheets of paper) great care should be taken to preserve the surface. If you cut through the gelcoat, your only other option is a costly paint job. Second, “Cleaner/Waxes” neither clean nor wax. They are cheap to buy, make detailing a quick process and do a LOUSY job. Two months after hiring a detailer using these products your boat will look like it did before he (or she) ever showed up and it will have far less gelcoat than before.
How to ACTUALLY protect it.
Step One: Wash the boat! Start from the top-down and from forward-aft. Use a good quality MARINE soap. Most household soaps have either abrasives in them or have chemical compounds that will strip wax. I prefer Mermaid's boat soap (and so does just about every single other professional yacht detailer). Take your time to do a good job here. A clean boat will dramatically reduce the amount of compounding necessary to achieve a proper gloss.
Step Two: (You must use a variable “slow speed polisher” to build up the appropriate amount of heat for most compounds to work effectively, usually between 1,500 and 2,500 RPMs. Compounding by hand will never achieve the appropriate level of gloss and automotive buffers oscillate way too fast which can damage the surface) Compound only as necessary. Not all parts of the boat will require the same attention. Horizontal areas exposed to sun will degrade much faster than vertical protected areas. Use only the mildest compounds necessary to achieve a suitable gloss. For protected areas, this will probably be a finishing material like finesse-it II (3M), while more exposed areas might require something meatier like Imperial Compound (also 3M). Only in drastic situations should a fast-cut or super-duty compound be used and even then, only with judicious use.
Step Three: Rag out the whole boat. A clean dry flannel rag (I go through about 20lbs of rags on a thirty foot boat) should be used to remove any swirl marks or residue left over from compounding. DO NOT SKIP THIS STEP! Be thorough, look at the surface from all angles. What looks nice with the sun behind you might look like a swirly nightmare with the sun in front of you. If the surface cleaned very well in step one, you shouldn't have major problems with this step.
Step Four: Sealing the boat. By this point the boat is polished and looks beautiful. Most people erroneously think wax is what gives it gloss. Nope. Wax will add a little gloss, but it's main objective is to seal and protect the gloss. For this reason, you want the wax that is strongest and longest lasting. The best paste waxes will have UV inhibitors in them. DO NOT BUY YOUR WAX FROM AN AUTOMOTIVE STORE! Carnauba waxes designed for automobiles are not designed to weather an entire season, much less an entire year (which is how often most people have their boats detailed), no matter what it says on the can.
The best way to seal the boats finish is with a two part system. The first step is to use a polymerized sealant (I use Starbrite's Teflon Marine Polish – it's both the easiest to apply and the longest lasting) and then follow it up with a coat of quality paste wax (3M Ultra-performance paste wax or Collinite's Fleetwax which is made for airplanes. Both are very good and have UV inhibitors).
If you follow these steps, not only will your boat look better, not only will it protect better, not only will it last longer, but, most importantly it will extend the life of your boat's finish and it will cost less to do each year.
End<<<<<<
mike
Re:Boat Detailing 16 years 4 months ago #5505
OK, I'll throw out a couple of questions to the experts. This is for my 64 Custom Craft. Used for about 1 season and then stored inside under a tarp until 2008. The gel coat is in excellent condition. Both when I got he boat and last year, I washed it with West Marine Citrus Boat Soap (chosen in part for environmental reasons)and covered it with the West Marine Teflon polish. Based on the article, I should be doing more.
The article describes a 4-step system. Steps 2 and 3 include compounding to achieve gloss. If I already have a high amount of gloss, I should be able to skip this step? Is there anything additional that compounding would do?
They also talk about marine polish and then wax for a final coat. Would the addition of the wax provide more than additional UV protection? I like the Teflon surface bacause it is easy to clean and is slippery (for the bottom). Is there any issue with year over year build up of the alternating layers?
Todd (aka thetudor)
1964 Custom Craft Aqua Ray
1959 Glastron Seaflite
1959 Tomahawk Spirit
Re: Boat Detailing 16 years 4 months ago #5512
Nice article. I contacted the author and got his permission to publish it in the main site. It's on the home page for now and will stay on the site in the Research section.
So, if anyone has a good article they would like published (Heather?), I'd be glad to post it for you.
Ken
Hello, World!!
Re: Boat Detailing 16 years 4 months ago #5518
  • Heather
  • Heather's Avatar
Yea sure put it up there.
Mine was not so much a detailing article but more a
"What to look for and beware of"
for the average boater.
Mrs Spookeay Bird
Re: Boat Detailing 16 years 4 months ago #5519
Yep, I got it... it's on the home page... thanks Heather.
Hello, World!!
Re: Boat Detailing 16 years 4 months ago #5521
  • g3jim
  • g3jim's Avatar
new boats out of the mold expect 5 years before any serious deterioration to the gel unless it gets whacked and ding'd along the way.
There is good info in his posting but he is trying to sell himself. I have a buffer and heavy duty compound as well as several other level of grit offered by 3M depending on the job ahead.
We all show up w/ tools, rags, compounds, polishes, & waxes when we provide the service of "Buffing and Waxing". I offer a seasonal service when I do and have not been thrown out of anywhere yet. newer boats with new gelcoat need less attention. A good boat owner keeps his/her boat clean to begin with. If I have to wash it too that gets tagged on to the final bill. When I show up to a place and there is an older boat (especially maroon) with an oxidized old finish well.....I break out the heavier stuff.
We have 10732 guests and no members online
