TOPIC: questions about floors and transoms
questions about floors and transoms 13 years 7 months ago #48470
Is it possible that the wood floor may be o.k. and the fiberglass has delaminated from it? how do I do core samples from the floor and transom? can I repair smaller areas of the floor and avoid doing the entire floor? :unsure:
Re:questions about floors and transoms 13 years 7 months ago #48478
ranthony,if you tried to load pics,and it didnt work they might need to be smaller(resized),pics would help,john
Re:questions about floors and transoms 13 years 7 months ago #48483
Just my opinion, and compared to many here I am a mere rookie, so keep that in mind, okay? Also not sure what boat you're working on, so construction materials are an unknown at this point.
Is it possible that the wood floor may be o.k. and the fiberglass has delaminated from it? Can I repair smaller areas?
Possible, yes - but not likely. If the fiberglass de-laminated from the wood, and allowed moisture underneath, odds are good that the floor will need replaced. Some folks have gotten away with replacing sections instead of the entire sole, it depends on how much of it needs replaced. If in doubt, it's best to replace it now while you're "in there" as opposed to having to go back in a couple years and do it again, IMO
You can drill small holes, inspect the "shavings" that come out. If they're light colored and dry, that's good. If they're dark and damp = rotted and bad.
Hope this helps, some pics would also assist the gang in giving you some solid advise. ;)
Re:questions about floors and transoms 13 years 7 months ago #48499
  • Andgott
  • Andgott's Avatar
As Mark said- Possible, but not likely. Do you have soft spots in the floor? Odds are, there is much more hidden underneath. The ply tends to rot from the bottom up.
What about the stringers? Do you know what condition they are in??
Doing the 'drill test' as Mark suggested will help determine condition of the transom, etc. Do it from the INSIDE.
Also, a good 'tapping' on the outside will help determine if the transom is solid. You should hear a good solid thud.
We have 5154 guests and no members online
