TOPIC: '65 Merc 1000 - High Voltage Output
'65 Merc 1000 - High Voltage Output 15 years 1 week ago #42852
When I got this motor the voltmeter read fine. I had to replace the battery and since then the meter pegs out when running at WOT. I've read that newer "maintenance free" batteries don't absorb excess voltage from older unregulated motors.
Anyone have experience with this issue? Am I at risk of frying things? Would installing an external regulator solve the issue? (If that's possible)
I've also read that simply running with all lights on may absorb the excess voltage, but I haven't tried this yet. Any thoughts or suggestions?
Re:'65 Merc 1000 - High Voltage Output 15 years 1 week ago #42855
I had a similar problem with my '63 1000. It killed my battery once after running WOT a while. I removed the rectifier and installed an early merc voltage regulator. Not appropriate maybe if you want to keep your classic motor classic, but I've added PT&T and hydraulic steering (and they said it couldn't be done...). I love my classic motor, but I don't mind updating it when I can!
Re:'65 Merc 1000 - High Voltage Output 15 years 1 week ago #42856
anything to make it safer and user friendly i say. my non-original console and new mercontrol would make the judges cringe, but i don't plan on being judged anymore at shows. i've had my time in the limelite..so to say. ron
Re:'65 Merc 1000 - High Voltage Output 15 years 1 week ago #42859
Thanks Frank! Would you happen to still have specific info about what you took out and what you replaced it with? Part numbers or descriptions and maybe even a schematic?
Kind of a noob when it comes to motor work, but I do know I need to get a service manual for the old beast!
Re:'65 Merc 1000 - High Voltage Output 15 years 1 week ago #42864
Randy has a good thread going in the Merc Outpost right now on this subject, Gary;
www.fiberglassics.com/glassic-forums/17-mercury-outpost/42799-things-to-know-about-your-charging-and-ignition.html#42858
And here's the link to the thread where Frank put one on his Merc, with part numbers and wiring instruction, I believe;
www.fiberglassics.com/glassic-forums/17-mercury-outpost/19022-new-voltage-regulator-for-my-63-merc1000.html#19022
Re:'65 Merc 1000 - High Voltage Output 15 years 6 days ago #43096
So, from this site and others I'm coming to the conclusion that the best and easiest thing to do is go back to an old style lead/acid battery. The motor has run well that way since '65, why fix what ain't broke?
My question now is, what specs do I want for the next battery? CCA numbers or whatever, what's recommended?
Thanks!
We have 5421 guests and 2 members online
