TOPIC: Electric circuit Nav light ?
Electric circuit Nav light ? 15 years 1 month ago #38661
Doing a rewire on my boat. I want to wire my bow nav light and stern running light on a 2 circuit 3 position switch. The switch has three connectors.How is this wired?
Re:Electric circuit Nav light ? 15 years 1 month ago #38662
  • 65G3
  • 65G3's Avatar
I just wired my lights .the positive terminal is the one in the middle, I think to the right ,looking at the switch from the top . The first pull is the stern light only, the second pull both lights come on
Re:Electric circuit Nav light ? 15 years 1 month ago #38663
Correct, the center terminal us usually the hot (+), one of the others will be the bow light, the other for the nav. If it works backards, switch the outer two connections. ;)
Re:Electric circuit Nav light ? 15 years 1 month ago #38664
So the hot from the fuse panel goes to the center terminal and the pos wire from each light goes to the other terminals. The ground wire from each light goes to the neg bus terminal?
Re:Electric circuit Nav light ? 15 years 1 month ago #38665
Yes sir, you got it.
Re:Electric circuit Nav light ? 15 years 1 month ago #38666
Thanks just wanted to check.
Re:Electric circuit Nav light ? 15 years 1 month ago #38719
  • 65G3
  • 65G3's Avatar
heres my switch wiring
Re:Electric circuit Nav light ? 15 years 1 month ago #38720
  • 65G3
  • 65G3's Avatar
try again..?? [img/ ]
Re:Electric circuit Nav light ? 15 years 1 month ago #38721
  • 65G3
  • 65G3's Avatar
We have 6664 guests and 2 members online
