TOPIC: Transom bolt holes
Transom bolt holes 15 years 3 months ago #31133
  • strobee
  • strobee's Avatar Topic Author
Back in the olden days we used this method to fill bolt holes in the transom. Drill the hole for good wood usually 1/2 inch. coat hole with fiberglass resin. Soak proper size dowl in resin. Drive dowl into hull before its resin is hard. Finish with Kitty hair or other filler and paint. I have taken transoms apart and this has seemed to work very well. Is there an advantage to the beveling and filling that seems to be the prederred method todaY?
Re:Transom bolt holes 15 years 3 months ago #31135
  • frog
  • frog's Avatar
  • Thank you received: 3
there are many ways to repair those holes, but if your methed works use it. sounds like a good and simple way to do it. frog
1965 Glasspar Avalon
We have 7046 guests and no members online
