TOPIC: Power Cat 18DC
Power Cat 18DC 16 years 7 months ago #2860
  • crosbyboat
  • crosbyboat's Avatar Topic Author
Yanked the 18DC out of the snow and put it back in the garage. Pulled the RideGuide steering system and figured out why it was so stiff. NOT a bad cable, but just an oxide build up in the steering tumbler. A little emory paper and grease and it works great. Started filling dash and transom holes. Motors under way too. To do list getting shorter.
Re:Powercat 18DC 16 years 7 months ago #2871
Crosby, ran into the same thing on my Cutter with the Rideguide. I (being a total rookie at the time) was ready to order the new cable. Then I started removing the helm and discovered the ancient grease had solidified, and allowed the oxidation to form "welding" the shaft into the hub. I ended up having to drive it out with a hammer and a large wood dowel used as a drift.
It's temporarily re-assembled now with the old bushings, but the "thrust washer" part of the plastic bushings is very brittle and breaking off in little pieces. Going to have to replace those when I pull it back apart for rebuild, did you replace or reuse yours?
Looking forward to watching as you bring that Powercat back to life, looks like you've already got a good start on it.
PS - I apologize for the "bad karma" comment between you and Ron, didn't know you were the two guys down the street having a BB gun fight for fun. ;)
Re:Powercat 18DC 16 years 7 months ago #2889
  • crosbyboat
Yup, well down the path on this one. Already been split in two, new transom in, top back on and transom cap done, exterior hull painted with epoxy. Mostly finishing work left. You can see the complete rebuild over on Danny Ledger's Power Cat site.
Ron and I poke fun at each other. He's a good guy. Ugly boat though. :woohoo: :ohmy:
Link to Powercat 18DC web site 16 years 7 months ago #2892
2:1 Paint 16 years 7 months ago #3701
  • crosbyboat
Lotso work on the 18DC today. Close to painting the topside. To that point, I HATE the bright yellow of Brightsides on the Powercat, but LOVE it on the Glen-L Missile. Two very different boats. Went to Lowe's and bought a 2.5 quart paint pail. Poured in a quart of Brightsides white, then started pouting in Brightsides yellow. 2 parts white to 1 part yellow gives you a nice butter yellow instead of School Bus yellow. I like it!
2:1 Paint 16 years 7 months ago #3702
  • crosbyboat
Lotso work on the 18DC today. Close to painting the topside. To that point, I HATE the bright yellow of Brightsides on the Powercat, but LOVE it on the Glen-L Missile. Two very different boats. Went to Lowe's and bought a 2.5 quart paint pail. Poured in a quart of Brightsides white, then started pouring in Brightsides yellow. 2 parts white to 1 part yellow gives you a nice butter yellow instead of School Bus yellow. I like it!
2:1 Paint 16 years 7 months ago #3703
  • crosbyboat
Re:2:1 Paint 16 years 7 months ago #3704
  • crosbyboat
Whoops! Sorry for the multiple posts. Loading a little slow, finger not.
Re:Powercat 18DC 16 years 7 months ago #3705
That 2-1 formula definitely tones down the yellow, I like it! My index finger twitches sometimes on my mouse hand, usually means I've had too much coffee. :ohmy:
Powercat 18DC Topside Primer 16 years 7 months ago #3882
  • crosbyboat
Spread a little primer on the glass repairs. Getting darn close to painting. A few little fixes of pin holes to do, but overall in great shape.
Powercat 18DC in Paint 16 years 7 months ago #3981
  • crosbyboat
This is Interlux Brightside applied with a 3" Wooster foam brush using the technique I described in the "Paint it Black" article posted on the site. Looks so sweet, and I am glad I custom mixed the Brightsides to tone down the yellow. Should get a second coat on today. Takes about 2 hours to lay down a coat. Hundreds and hundreds of hours to get ready to paint. I'm thrilled.
Re:Powercat 18DC in Paint - Brightsides Coat #2 16 years 7 months ago #3996
  • crosbyboat
Got #2 on after playing with the Mercury 1350.
Re:Powercat 18DC in Paint - Brightsides Coat #2 16 years 6 months ago #4822
  • crosbyboat
There's only one way to sand an 18DC...one groove at a time. A file wrapped in 220 does the trick. Deck is sanded after two coats. Port fin wet sanded. Stbd side and fin, the total rebuild side, I heavily sanded tonight. Splash well is good. Almost ready for motors. Should be ready for another couple of finish coats soon. Motors nearly done. RideGuide steering and conversion to OMC figured out. Making great progress. Should see water soon.
Re:Powercat 18DC in Paint - Brightsides Coat #2 16 years 6 months ago #4827
Nice work, one step at a time...
Hello, World!!
Re:Powercat 18DC in Paint - Brightsides Coat #2 16 years 6 months ago #4828
She looks great - but then I'm a sucker for yellow!
Peter
in Denver
Re:Powercat 18DC in Paint - Brightsides Coat #2 16 years 6 months ago #4834
  • crosbyboat
And this weekend I polished these little gems with Cameo metal polish and a toothbrush. Not perfect, but they'll do until the kids are out of college!
Re:Powercat 18DC 16 years 6 months ago #4835
Lookin' good, B! She's coming along nicely, you'll be out there enjoying the fruits of your labor SOON.
Re:Powercat 18DC 16 years 6 months ago #4844
  • bilnan1
  • bilnan1's Avatar
  • Thank you received: 14
Heh Brian,, How are your windshields, when I get ready to do mine I am going to need them all Thanks Bill
Re:Powercat 18DC 16 years 6 months ago #4902
  • crosbyboat
Pretty bad. I am negotiating to get them polished to see if the haze and scratches can be removed. Fall back is to have new ones made. There's a place across the Hudson that will do it. I'm sure they as soon make 4 rather than 2. Not certain what I'm doing with the top windshield but suspect (highly) I won't use the old tall one, but rather will keep it low and more rakish in it's look....and so it will fit in the garage. Also going to be ordering new windshield gasket and need to have a die made. If you need gasket, would love to split the cost of the die with someone.
Re:Powercat 18DC 16 years 6 months ago #5192
  • crosbyboat
Coat #3 on, and I'm calling it done, except for one more sanding of the dash. Great day of work on boats. Next weekend headed to the St. Lawrence. Added a couple more photos of work in progress before pulling the tape.
Re:Powercat 18DC 16 years 6 months ago #5198
  • Heather
  • Heather's Avatar
Very Nice work. Shines like a New Penney!
Mrs Spookeay Bird
Re:Powercat 18DC - A Little Bling 16 years 6 months ago #5245
  • crosbyboat
Thanks to Gary Larson of Niantic, CT who gifted these Power Cat logos to me. Stopped after church and picked up the mounting bolts for them. They look great. Lots more to do, but making progress every day.
Re:Powercat 18DC 16 years 6 months ago #5260
  • Bigfoot
  • Bigfoot's Avatar
Nice work, I just read this whole link plus viewed all those pics that frank posted the link to. That boat is so cool looking and I read that "paint it black" article in the past a bunch of times.
I really want to see pics of it on the water.
My eyes have just opened up to these old classic cuddy cabins this past year. That power cat is one that I would love to own. I bet that will be one smooth ride, Mike
Re:Powercat 18DC 16 years 6 months ago #5352
  • crosbyboat
Dick Davis' old 18DC is currently available in MN, but don't pay what they're asking.
Re:Power Cat 18DC 16 years 6 months ago #5736
  • crosbyboat
Another coat of Interlux VC Performance Epoxy on the sides and three on the transom. Maybe one more on the transom since it's all mixed. Am about 24 hours away from being ready for motors.
Re:Powercat 18DC 16 years 6 months ago #5745
  • Bigfoot
  • Bigfoot's Avatar
I finally figured out where I saw this thread!!! Been looking for a week, anyways do you have a link or info on that dc that's for sale, Thanks Mike
Re:Powercat 18DC 16 years 6 months ago #5751
  • crosbyboat
It was posted on the PowerCat site as a Craig's List add in MN. I'll see if I can find it there.
Re:Powercat 18DC 16 years 6 months ago #5766
Not sure if this is the link you were referring to, but it is an 18ft Powercat
minneapolis.craigslist.org/csw/boa/1710082650.html
Re:Powercat 18DC 16 years 6 months ago #5779
  • crosbyboat
That's the one. It's Dick Davis' old boat, but he says it needs transom and cores. Cores are easy, flat and plywood. Transom, the top has to come off like mine. That said, I know of only 5 or 6 that made it for 50 years.
Re:Powercat 18DC 16 years 6 months ago #5802
  • crosbyboat
More work today. After church, sanded the transom and gave it a final coat. Installed a 1/2" chromed lifting ring on the bow. This actually goes through the deck and bolts to a very heavy duty glass tab that in turn is glass to the hull. Sort of helps hold the top to the bottom, but is the main tie off for the bow. Also installed chrome transom rings. Then put 1/4" bolts through the stbd side and pulled the top to the bottom and got out the drill and rivet gun. Time to order T-bolts and measure the rubrail I have to see if will make it with the original.
40 Feet of Rub Rail Needed 16 years 6 months ago #5973
  • crosbyboat
I have enough of the original rub rail to replace it. I have three 12' sections and the bow wrap around. The bow piece is pretty scratched up, but I have no options. Started wet sanding it tonight and got all the old T-bolts removed. It'll be fine. That's why it's called patina.
Boys of the Hood 16 years 6 months ago #5974
  • crosbyboat
The hoods for the 1962 Larks before dressing up.
Re:40 Feet of Rub Rail Needed 16 years 6 months ago #5984
  • crosbyboat
Ouch.....!!! Found what I need at Rockler.....$1.09 per T-bolt...$65 for 50 bolts with shipping; figure 1 every foot or so. YYEEOOUUCCHH!! Course Rockler has never been cheap, but they have what you need.
Power Plant #1 16 years 5 months ago #6256
  • crosbyboat
Thanks Chinewalker for working on this. All back together. Tomorrow I'll do a little painting. This one is ready to start. #2 is in the basement and is also all put together and ready to start. Just need to carry it up. And, thanks again Chinewalker for steering components. Took everything apart and sorted it all out. And thanks Frank for the vice! 50 year old dissimilar metals don't like to come apart. Making good progress.
Re:Power Plant #1 16 years 5 months ago #6273
Those are my favorite evinrudes. I love the style of this model. I've got a couple myself.
Twin 1962 Evinrude Lark 40 hp - Ready to Mount 16 years 5 months ago #6321
  • crosbyboat
I painted this pair of bad boys this afternoon. As soon as my daughter and her boyfriend get back from shopping I'll be setting this pair of motors on the back of the Power Cat. Been a L-O-N-G road to get here, and it's an exciting day. Heading to Frank's Place now to thread a 4' steel rod to connect the two motors. Center to center the front of the motors are 50" apart!
18DC - Motors Mounted 16 years 5 months ago #6326
  • crosbyboat
Haven't tightened them down yet. A little more to do on the connecting rod between them. Once I have them pointed dead ahead and the connecting rod on I'll tighten them down. 22 months of work on this beast so far to get to this day I've been dreaming about since the Raceboat Regatta in 2008 when I dragged it home.
Re:Power Cat 18DC 16 years 5 months ago #6327
Looking good B. Get 'em bolted down and you're one GIANT step closer to launch!
Fat Boy (Phat Bouy?) :laugh:
Re:Power Cat 18DC 16 years 5 months ago #6329
  • crosbyboat
LOL...this one seems to have already gotten a name; "Double Wide".
Re:Power Cat 18DC 16 years 5 months ago #6335
  • Bigfoot
  • Bigfoot's Avatar
Please remind me the horse power of those motors.... It's looking great.
Time to create page: 0.135 seconds
We have 18871 guests and one member online
