TOPIC: tachometer wiring
tachometer wiring 15 years 7 months ago #24681
Hi My name is gary I have a 1968 sea king 14' runabout It has the original 45HP sea king motor [crysler] with a factory in dash tach There are four conection points on the back of the tach. I know the white wire from motor gose to tach . None of the connections are marked Can someone tell me how to wire it correctly Thank You for feading Gary
Re:tachometer wiring 15 years 7 months ago #24687
This should get you started.
Hopefully the terminals on the tach will have stamped markings on them.
Instructions.
Things You'll Need:
Wire crimper, pliers-type
Wire, stranded copper 18-gauge AWG, Red
Wire, stranded copper 18-gauge AWG, Green
Wire, stranded copper 18-gauge AWG, Gray
Ring connectors
Blade disconnects
Screwdriver
Soldering iron
Silver core solder
1.
Disconnect the boat's battery.
2.
Strip 1/2-inch of insulation from both ends of all the wires. Use a pliers-type crimper to crimp ring connectors to both ends of the one of the red wires and the black wire and one end of each of the gray wires. Crimp a female blade disconnect onto one end of the remaining red wire and a ring connector to the other end.
3.
Loosen the nut on the "NEG" post of an instrument adjacent to the tachometer location that's activated by the ignition switch. Slip one of the ring connectors on one of the red wires onto the post, thread the nut back onto the post and tighten. Slip the connector on the other end of the wire over the tachometer post marked "BAT."
4.
Slip one of the ring connectors on the green wire onto the terminal post on the back of the tachometer marked "GND." Remove one of the screws on the boat's common ground, slip the connector on the other end of the black wire over that screw and thread the screw back into the common ground, tightening the screw with a screwdriver.
5.
Slide the female blade disconnect onto the male blade disconnect on the back of the tachometer. Attach the ring connector on the other end to the "POS" or "+" post of an adjacent, lighted instrument.
6.
Solder the bare ends of each of the gray wires to the bare ends of the wires coming from the sending unit with a soldering iron and silver core solder. Connect the ring terminal of one of the gray wires to the "GND" connection on the back of the tachometer and the ring terminal of the other gray wire to the "SIGNAL" terminal of the tachometer.
Re:tachometer wiring 15 years 7 months ago #24729
MyFlamingo Thank You very much for your help There are no markings on it for the terminals I beleave I can find the neg. side with an ohm meter Thanks againg I'll give it a try Gary Metts
Re:tachometer wiring 15 years 7 months ago #24730
Your 4 terminals are probably power, pulse, ground, and light. Usually there are markings by the studs on the back that indicate what stud does what. Can you get us a shot of the back of the tach?
Another idea would be to post this question on the JEGO forum. You may very well have a wider & more specific audience there for this question. Lots of folks have those Sea Kings.
Best of luck!
We have 7064 guests and no members online
