TOPIC: Need Help
Need Help 15 years 6 months ago #23899
I was wondering if anyone has a good way of freeing up motors. I have a mark 55e and i tried penetrating oil but no luck. Any help would be greatly appreciated.
Thanks in advance
Re:Need Help 15 years 6 months ago #23900
Marvel Mystery oil, lots of it. Pull the lower end it might be frozen and not the block.
Re:Need Help 15 years 6 months ago #23901
i pulled the lower end it was free i have the block tore down completely i just cant get it to free up
Re:Need Help 15 years 6 months ago #23902
  • Neil
  • Neil's Avatar
Yes Marvel
Let it soak. Don't force anything. Let it help you by doing its job.
Patience. Dont get heavy handed and break, bend, or destroy things that will cost later.
Neil
Neil and Mary Ousnamer
Re:Need Help 15 years 6 months ago #23904
which product is the right one?
Re:Need Help 15 years 6 months ago #23907
  • Neil
  • Neil's Avatar
I'm sorry.
As Daveswaves posted, it is Marvel Mystery Oil.
Neil
Re:Need Help 15 years 6 months ago #23908
i went on theyre website and one is for adding to fuel and the other is air tool oil im guesing the one you are talking about is the one you add to the gas? would this mean id just pour it into the cylinder?
Re:Need Help 15 years 6 months ago #23910
Here on the Gulf Coast with rust, and also working with old restaurant equ that Noah use on the ark I have found something that works better that anything that you can buy from any store....Problem is not to many places sell it so you may have to order it Shamrock's S'OK
Let it do it's thing for a few days, if the unit is stuck still spray again and do once a day for a few days.
I have then if the piston it still stuck I take an old spark plug, break the glass off drill a hole through the plug; and weld a 1/8 pipe nibble to it
Then I screw a grease cert to the nibble...I put the plug in to the cyl and pump grease in pushing the piston out good even pressure no beating anything up
www.shamrockspecialties.net/SOK.htm
www.alexgs.com/product/shamrock-s-ok-pt.html
Re:Need Help 15 years 6 months ago #23912
sound like a good idea ill take it up with my dad see what he says about it. Thanks
Re:Need Help 15 years 6 months ago #23915
Thats right, the air tool oil is something new out. The add to the gas one can be added to the engine oil as well and has been used for years to free up stuck rings etc.
Re:Need Help 15 years 6 months ago #23916
If you can't get the crank out do this. Carefully drill out the connecting rod bolts.
Now you can remove the crankshaft.
Now you can work on the pistons one at a time.
Re:Need Help 15 years 6 months ago #23945
Professor is on the money (as usual). Those 4-holer Mercs can be a pain to free up if they're stuck bad. Usually, you can reach one or two of the rods enough to get at the nuts on the under side of the bolts. Remove what you can and then work on the ones you can't. I have a brass dowel that fits through the spark plug holes. I set the block, crank side down, on a jig in a hydraulic bench press. Using the dowel, I press the stuck pistons out, sometimes alternating each one a little at a time as you don't want to torque the crankshaft. Work them out slowly. The jig allows space under the block for the pistons/rods/crank to move as they come out. Once you can access any/all of the nuts on the rod bolts, remove them. Once you get the crankshaft out of the way, the pistons are much easier to punch out with the dowel - just drive them out. Continue to work slowly, as if the dowel slips, it can damage the plug threads. Make sure the dowel has a flat tip so as to avoid damaging the piston crown. DO NOT beat on them or you will damage the pistons and plug threads.
I have a bunch of Mark 55 powerhead parts here, including a crank, some rods and I think a serviceable block if it comes down to that...
- Scott
Re:Need Help 15 years 6 months ago #24046
Thanks everyone for the ideas
We have 9674 guests and one member online
