TOPIC: 63 Westfield: How to remove rub rail? New source?
63 Westfield: How to remove rub rail? New source? 5 years 11 months ago #143142
After months of pandemic-induced delay I'm finally here in Canandaigua doing little fix-it jobs on the '63 Westfield that I inherited last year. The full length storage shelf on the starboard side is hanging loose because all the through bolts have failed. This is especially important to fix because the shifter is mounted to it in front. The shelf has metal brackets that hang from those through bolts, which are threaded into a full length stringer using some weird washer/nut hybrid (kind of cone shaped/recessed into the stringer). I figure I'll replace the weird nuts with fender washers and nylock nuts, but first I have to get the old bolts out. Their heads are under the white rubber insert in the lower rub rail (along the side of the hull, not at the gunnel). That stuff is pretty hardened at this point and seems very unwilling to slide out of its slot. Any advice for how to remove it? In the absence of any better ideas I'll probably try to soak it with hot soapy water, and maybe gently heat it with a heat gun on low.
While I'm here, two of the well nuts have failed where the driver's seat front edge is fastened. I kind a figure it would be smart to replace them all proactively, but the others are in there pretty good and I don't know how to remove them. I'll probably just leave them alone unless someone can tell me how to get them out.
I may have other questions before this already-much-shortened season comes to a close.
Dan
63 Westfield: How to remove rub rail? New source? 5 years 11 months ago #143144
Most rub rails have a metal back frame with a rubber insert. Best way I use is to go the the end of the rail where there is usually some type of decorative end cap. Remove the cap and take a screwdriver and pry up on the rubber insert. Once it starts to peel out it usually goes pretty easily. Pull the insert off until you get to where you want to be. As you said a little soapy water will help lube especially when you push it back in place.
63 Westfield: How to remove rub rail? New source? 5 years 11 months ago #143172
are you wanting to replace the insert if so then very careful if not put a hole in a piece with a screw driver then start prying .
63 Westfield: How to remove rub rail? New source? 5 years 11 months ago #143193
Thanks for the replies. The rub rails on the sides of the hull don't really need to be replaced. I'll probably wait to pry them out until I have a source for a replacement, in case they get damaged. The gunnel rub rails do need to be replaced so I need to track down a source for something that would work there. Any suggestions?
Thanks.
63 Westfield: How to remove rub rail? New source? 5 years 10 months ago #143331
FYI, I found what I needed at Taco Marine. They sent me little samples of two similar profiles, one available in black or white and the other only in black. Thankfully for me, they both worked so I got the one in white to match the original. I think the 50' will be enough to replace both the gunnel and splash rails.
63 Westfield: How to remove rub rail? New source? 5 years 9 months ago #143430
Glad the white one worked.
What was the Taco Marine part # for white? I ended up switching to the black one for my 1962 Edinboro.
63 Westfield: How to remove rub rail? New source? 5 years 9 months ago #143431
From the email invoice:
V12-0317
Part Number: V12-0317WHA50-1, Flexible Aluminum, Arctic White Rub Rail Insert, 1/2"W x 1-1/4"H x 50'L
I think I would have been happy with black for the gunnels, echoing the black in the upholstery. But I didn’t think I’d like it in the splash rails.
We have 7981 guests and one member online
