TOPIC: No luck with searching. Need fuel pump 1959 58a
No luck with searching. Need fuel pump 1959 58a 8 years 4 months ago #135018
I have been trying with no luck using sites search feature. I know I got advice before to buy parts for my 1959 mark 58a. Please one more time where is place to find fuel pump kit Thanks in advance?.
No luck with searching. Need fuel pump 1959 58a 8 years 4 months ago #135019
  • bilnan1
  • bilnan1's Avatar
  • Thank you received: 14
NAPA,,tell them to look in their marine book,they get them from SIERRA boat part will have it too but napa quicker,,see ya soon BILL
No luck with searching. Need fuel pump 1959 58a 8 years 4 months ago #135021
  • Thank you received: 128
Marineengine.com is a great place to look up parts. They have a flat rate shipping which is good for ordering lots of parts. You can usually look up your motor directly by serial number or drill down into the diagrams to find the hp range then serial #. Once you know the P/N you can shop around, too.
The OE P/N for your fuel pump repair kit is 23014A1, and the Sierra P/N is 18-7804.
As Bill said, many Sierra parts are available under the Napa Small Parts line.
The NAPA parts nomenclature uses "SME" plus the Sierra number without a dash.
Ergo, your Sierra part 18-7804 becomes "SME187804". Searching www.napaonline.com gives the following result:
www.napaonline.com/en/p/SME187804
This is a common kit that fits lots of old Mercs, so they'd probably have it in the warehouse.
Or check eBay if you're willing to wait for the part to ship, tons of them available for even cheaper:
www.ebay.com/dsc/Boat-Parts/26443/i.html?_sac=1&_sop=15&_vxp=mtr&_from=R40&LH_TitleDesc=1&_nkw=mercury+pump+%287804%2C+23014%29&LH_PrefLoc=1&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xmercury+pump+%287804%2C+23014%29.TRS0&_osacat=26443&_odkw=mercury+outboard+fuel+pump+kit+-water+-impeller
There's your parts lesson for the day!
HTH.........ed
The following user(s) said Thank You: Dave the Wave
No luck with searching. Need fuel pump 1959 58a 8 years 4 months ago #135022
I've had too many failure issues with this specific Sierra fuel pump kit, and strongly suggest snagging an OEM 23014A1 kit instead.
OR,...If you suspect that you need the valves too,...OEM kit # 21-30430A1 is your part number.
The Sierra kit's cork gaskets swell & distort, causing failures.
doc
No luck with searching. Need fuel pump 1959 58a 8 years 4 months ago #135023
No luck with searching. Need fuel pump 1959 58a 8 years 4 months ago #135044
Thanks so very much!!
1962 Scott - last chance!
( / Parts / Miscellaneous)
04-14-2026
Attwood 6000-09 Green & Red Side Light
04-14-2026
We have 8357 guests and no members online
