TOPIC: How to repair?
How to repair? 9 years 11 months ago #126099
  • Mr. Asa
  • Mr. Asa's Avatar Topic Author
Well, the really ugly patch in the back of my Herter's is pretty bad, and one of the ones up front isn't the best either although the repair seems better.
Time to learn how to fiberglass, I guess. Does anyone have a good how-to they like or other resource?
One of the things that concerns me is back around this patch it appears sunken in, I worry that after patching it won't be level back there.
I didn't get a before pic of this, although you can see on the inside that there is a puncture
At least the crappy camo paint is still coming up well
It's shiny here because I rinsed it off with a hose.
Re:How to repair? 9 years 11 months ago #126111
Read some of the info on West Marine's site for WestSystem epoxy. Those guys literally wrote the book.
Then go buy your epoxy from duckworksbbs.com Get the house brand stuff and save yourself a ton. It works great.
If you're a visual learner, I've been reall impressed with Boatworks Today's videos on youtube. He's got a multipart series called There's a Hole In My Boat or some such
Don't worry too much about low spots, you should be able to build them back to level with resin.
Re:How to repair? 9 years 11 months ago #126112
I have a question that goes with that. I've helped a friend do some minor repairs on a couple Vettes he has and always questioned whether or not auto body filler was the right stuff to level glass. Are Bondo and spot putty acceptable when working on a hull ? Thanks in advance. Mark.
Damn the torpedoes, full steam ahead !
Re:How to repair? 9 years 11 months ago #126113
I'm far from an expert on this stuff, but my past automotive experience with all things Bondo brand was miserable. I run from their products.
I've heard discussions of 'fairing compound' for doing the final skim and leveling coats on hulls but I'm not sure how it's different than regular epoxy.
Re:How to repair? 9 years 11 months ago #126114
Good to know. I use "Bondo" as a generic term for all body filler. The Canadian Tire brand is pretty good but I've never used it on glass that was going to be immersed in water. I guess I'll have to learn more about finish applications with resin. Thanks :)
Re:How to repair? 9 years 11 months ago #126115
Epoxy is a type of resin so is polyester and vinylester . Fairing compound is just a thickened resin whether its epoxy , poly or vinyl . One of the popular thickeners is cabosil , its makes a light weight sand able faring compound . Some of the other thickeners are talc , wood flour and chopped or ground glass fibers , the added glass fibers are good for building up areas . For your repair you could use polyester resin its what your boats made out of .
Re:How to repair? 9 years 11 months ago #126118
What you have is a piece of cake repair. I've done many that have been a lot worse. Here is a link that I think would be very helpful for you and anyone else with this problem.
Happy boating.
Cal
boatworkstoday.com/archives/1460
Re:How to repair? 9 years 11 months ago #126121
Great link Cal. Thank you. It's bookmarked for the G-3 come spring. Mark.
Re:How to repair? 9 years 11 months ago #126428
Great link. I watched the first couple videos and now it looks like I'm going to spend the rest of the evening watching the rest of them. Great info. Thanks for sharing. -Terry
Time to create page: 0.147 seconds
We have 12495 guests and no members online
