TOPIC: Outboard Noise Reduction
Outboard Noise Reduction 10 years 1 month ago #123365
  • damartinca
  • damartinca's Avatar Topic Author
The original spongy foam on the inside of my cowl (1966 100 Hp Johnson Golden Meteor) is beginning to deteriorate. I'm actually amazed it has lasted this long without damage.
Are there recommendations for replacement products that could actually reduce the noise better over the original foam?
David
Re:Outboard Noise Reduction 10 years 1 month ago #123367
Dynamat - works great to quiet hot rod car interiors - should work well.
Re:Outboard Noise Reduction 10 years 1 month ago #123383
Yeah I used the 3/4" foam at Joann Fabrics and it worked a little but the dynamat should work good even if not original.
Re:Outboard Noise Reduction 10 years 1 month ago #123513
  • JerryF
  • JerryF's Avatar
Dynamat for sure. I used that inside the cover of a Johnson 30hp (2cyl). It not only made an improvement in the overall noise level but also seemed to smooth out difference between the high and low tones. Be sure to cover the whole of the inside. The original foam was only on the cover sides but I put it everywhere and I think that was worth the extra work.
Jerry
Re:Outboard Noise Reduction 10 years 1 month ago #123514
  • damartinca
Thanks Everyone.
Here is the official response I got from Dynamat.
We recommend two products for the cowl on your outboard: Xtreme and Hoodliner.
First, install the Xtreme. This product will damp any vibrations/resonations in steel, fiberglass, or wood panels to reduce structure borne noise.
Over the Xtreme, install our Hoodliner. Hoodliner is a 3/4-inch-thick, peel and stick, acoustical foam with an aluminized Mylar face that will help to reduce airborne engine noise and heat.
Of course, all the old insulation and old adhesive will need to be removed before installing Xtreme and Hoodliner.
Please let us know if you have any other questions.
Best regards,
Technical Solutions
Dynamic Control of North America Inc.
www.dynamat.com
Re:Outboard Noise Reduction 10 years 1 month ago #123531
Cool Dave I'll have to check that out. The 3/4" foam I installed isn't staying on very well and it's still pretty loud so I may switch if it isn't too expensive.
Time to create page: 0.107 seconds
We have 7252 guests and one member online
