TOPIC: 59 Johnson 50hp alternator ?
59 Johnson 50hp alternator ? 9 years 10 months ago #123315
Got a 59 Johnson 50hp. Can I hook up and alternator? If so where do I get one? It has electric Start. But I would like to have an alternator hooked up to help out. From my Google searching I seen one on eBay that sold that looked like it bolted into the hole on the opposite side of the starter
Re:59 Johnson 50hp alternator ? 9 years 10 months ago #123327
David,
Welcome aboard! So that hole you see on the other side of the motor, that looks like another starter would fit, is for a generator. They are as hard to find as hens teeth and if you do find one it will probably cost you and arm and a leg. I have a '59 Evinrude Golden Jubilee 50hp "Fat Fifty" and have the same empty space. I don't know if you can adapt an alternator to work or not. Maybe someone who had can jump in here.
Re:59 Johnson 50hp alternator ? 9 years 10 months ago #123334
I wonder if a generator from a Big Twin would fit. I won't ever run my '58 Starflite enough to need a generator, but am intrigued...
Larry
Re:59 Johnson 50hp alternator ? 9 years 10 months ago #123386
Not an expert but probably should work.
Re:59 Johnson 50hp alternator ? 9 years 10 months ago #123390
  • Thank you received: 128
Here's a V4 generator at auction on eBay:
You'll need a belt as well:
BTW it looks like the V4 and Big Twin generators are the same except for bracketry.
Here's a voltage regulator, might be the hardest thing to find (not cheap, either!):
Last but not least, attached is a wiring diagram for an electric-shift Big Twin with alternator. Of course the pertinent part of the diagram is the alternator connections.
Maybe you'll luck out and find a relay box on Craigslist or eBay from a generator motor; it'll have the regulator mounted along with all the wiring.
HTH, G'luck...........ed
Re:59 Johnson 50hp alternator ? 9 years 10 months ago #123409
Wow I that generator goes for the current price it's a steal!!!!!!!!!!!!!
Re:59 Johnson 50hp alternator ? 9 years 10 months ago #123541
Wow! Sold for $12.99! Even with $18.50 shipping that is a steal!
Larry
Time to create page: 0.721 seconds
Glasspar Tacoma
Glasspar Tacoma
05-04-2026
1962 Scott - last chance!
( / Parts / Miscellaneous)
04-14-2026
We have 6831 guests and no members online
