TOPIC: How do I order the right fuel tank sender?
How do I order the right fuel tank sender? 10 years 10 months ago #113966
Fuel gauge is on the dash, tank is under the floor. Old sender is corroded and gives low tank level readings.
Seems like a lot of the sites selling fuel senders don't specify hole diameter, bolt pattern, and some don't list arm length or ohm rating.
And speaking of ohm rating, mine is pretty well cooked and doesn't cooperate when I try to get a reading.
If it's an American factory install (1979) can I assume it's standard? (beyond arm and ohm)
Re:How do I order the right fuel tank sender? 10 years 10 months ago #113967
  • Nautilus
  • Nautilus's Avatar
  • Thank you received: 58
Just about all sending units are calibrated to 35-240 Ohms but getting the reading to register the true level of the tank could be a problem. If you know the capacity of the tank, fill it to 1/4 capacity and see where the needle registers. That's the mark you need to know. Anything above that is clear sailing. It may not be THE answer you're looking for but it beats running out of gas.
However, the real issue is hole alignment. The best way to approach the problem is to measure what you have and ask the seller to measure his. Something like this might do:
Mentor to the unenlightened!
"Success makes...
Re:How do I order the right fuel tank sender? 10 years 10 months ago #113968
Your gauge might say in tiny numbers what the ohm range is. If they don't match exactly they will close and the indicator will only be off by a little bit.
They are pretty universal now, the arm lengths are adjusted to your tank. My hole diameter was the same on my 1962 metal tank as the one they sent me, maybe yours will work too.
Time to create page: 0.551 seconds
We have 8756 guests and one member online
