TOPIC: 1967 17' MFG Tri Hull Outboard Question
1967 17' MFG Tri Hull Outboard Question 11 years 2 weeks ago #113892
We own and operate a 1967 MFG 17' Fiberglass 'Tri Hull' Outboard boat. I have searched Google images, MFG.com (Jim Coffman's site) and can't find a brochure, image, or any info on our model. I know my dad purchased the 1967 model in the spring of 1968. It is blue on top with white hull. The upper deck is designed for standing not sitting. There is no center window and low rails long each side of the upper deck.
Any ideas as to which model I have?
thanks
david
Re:1967 17' MFG Tri Hull Outboard Question 11 years 2 weeks ago #113893
See the link to the brochures: www.fiberglassics.com/library/MFG
There is a pretty complete set of brochures from the 1960s and 1970s here so you should be able to find your model.
Good luck!
Andreas
Re:1967 17' MFG Tri Hull Outboard Question 11 years 2 weeks ago #113896
Welcome aboard David, glad to have you here. Sounds like a nice "family" boat. check the Glassic Library here as Andreas said, it's probably in there.
Re:1967 17' MFG Tri Hull Outboard Question 11 years 2 weeks ago #113900
Really neat that it has been in the family since it was new!
Re:1967 17' MFG Tri Hull Outboard Question 11 years 2 weeks ago #113903
Also, MFG purchased Crestliner sometime around then, you may find your boat with Crestliner name on it (Crestliner Muskie and MFG Gypsy were same boat).
MFG sold off Crestliner in 73.
We have 6288 guests and no members online
