  • 2
TOPIC: Delmar restoration
Re:Delmar restoration 11 years 2 months ago #103358
Wow, you're really moving along!
Re:Delmar restoration 11 years 2 months ago #103403
  • commando
  • commando's Avatar Topic Author
Re:Delmar restoration 11 years 2 months ago #103404
  • commando
So I flip the boat over today ad found a lots of crack on the gelcoat so I think it is better to sand it down and reglass the whole bottom again. The boat in the back is a 1959 Larson senior not mine belong to a friend I'm just doing the work for him.
Re:Delmar restoration 11 years 2 months ago #103405
  • frog
  • frog's Avatar
  • Thank you received: 3
wow Bill, your really going to have a great looking boat when your done, good work so far. greg
Re:Delmar restoration 11 years 2 months ago #103501
  • commando
Did some body today . don't like it much but have to do it.
Re:Delmar restoration 11 years 2 months ago #103642
  • commando
Got more work done she got a coat of gel coat on.i had to grind all gel coat off the deck cause it was cracked everywhere.
Re:Delmar restoration 11 years 1 month ago #103769
  • commando
For the deck I finish glassing the top side with 1 lay 18oz woven and 1 oz mat the flip it over and replace all wood reinforce then i glass it all in then I gelcoat it.
Re:Delmar restoration 11 years 1 month ago #103770
Going to be a sweet ride, wish I had a place like that to work, this outdoors in freezing cold is no fun, no wet sanding for 2 days :(
Re:Delmar restoration 11 years 1 month ago #103771
  • commando
It cold here too -1 today.I wanted to sand the hull but 3 days now it's still tacky.
Re:Delmar restoration 11 years 1 month ago #103772
I know how you feel, keep up the faith, I just need a boat in the water so I can have the will to keep working.
Re:Delmar restoration 11 years 2 months ago #103821
Command has got skills! nice work!
Re:Delmar restoration 11 years 2 months ago #103823
  • commando
Just trying my best to do it nice and stay out of trouble.I still got a long way to go to get it done but I try not to think about that it seem like to much work.back to work tomorrow at regular job so less time for her now.
Re:Delmar restoration 11 years 2 months ago #103840
Looks good - that boat will probably be better than new
Re:Delmar restoration 11 years 2 months ago #103853
I tackle every project by breaking it up into small goals and if those goals turn out to be more than I can chew I break it up even more. and try try try try, but fail not to start another project before i finish the current one.
Re:Delmar restoration 11 years 2 months ago #103858
I need to do that but starting something new keeps it interesting
Re:Delmar restoration 11 years 2 months ago #103861
thats why i fail
Re:Delmar restoration 11 years 1 month ago #103949
  • commando
Ran out of filler today and it's weekend so I couldn't do any body work and hull is not ready to sand down yet for 2nd coat of gelcoat so I fiddle around with making a mold for my top winshield also I am trying to make a swim grid and engine pod upside down which is a little bit tricky and not sure if it will look or work okay But the cool thing is I went to a flea market this morning and found a nice bow light for $10.
Re:Delmar restoration 11 years 1 month ago #103985
Very cool, great progress, love the light!
Re:Delmar restoration 11 years 1 month ago #104013
  • commando
Got more filler today so on the deck it goes almost done with body work I just have to dye the deck and board it down to find low spot.I made a fiberglass mold for the hull extension and dry fit it and everything line up good I hope my pod and swim grind works or else it a waste of time not only that I don't want to have to fix anything once my boat is all done.
Re:Delmar restoration 11 years 1 month ago #104015
Dang you're fast bro
Re:Delmar restoration 11 years 1 month ago #104016
Too bad going back to work has slowed you down. Haha. Your skills are very impressive.
Re:Delmar restoration 11 years 1 month ago #104018
  • commando
Hahaha 8 hrs for work 4 hrs for the delmar.12 hrs a day but I have fun doing it.glassing my pod on to the boat upside down suck resin dripping all over me I can't flip the boat over yet the gelcoat is not fully cure.it's really hard work sanding the hull and deck all by hand I just to get it as straight possible.
Re:Delmar restoration 11 years 1 month ago #104145
  • commando
Got hardware all done and ready to install.
Re:Delmar restoration 11 years 1 month ago #104150
im assuming you got it chromed if you did how much and what shape was it in before. if not lucky you didn,t need chroming ha
Re:Delmar restoration 11 years 1 month ago #104155
  • commando
Just polish aluminum no chrome it was pretty bad shape old and ugly before .
Re:Delmar restoration 11 years 1 month ago #104161
did you remove the anodize or just polish?
Re:Delmar restoration 11 years 1 month ago #104162
  • commando
Just sand and polish and a lot of patients.
Re:Delmar restoration 11 years 1 month ago #104184
  • commando
Body work is all done all I have to do is check it over and clean it then I can spray gelcoat on her but no gelcoat yet still on order.
Re:Delmar restoration 11 years 1 month ago #104431
  • commando
Well I finish all of the body work on the extension and the deck also I spray a coat of sealer on it everthing look very straight and all good to go ahead with my final choice of color in gelcoat.my gelcoat arrive today so maybe this weekend I can spray it if the weather is nice enough.the bad news is no one get to see what color it is hihihi so next time I post is the interior work on this boat only that might be awhile cause of the time it took to wet sand and polish the boat and mate the deck to hull stage. I'm curious if you guy look at the extension can you tell if it is a add on or not I just want to know your opinion. Thanks
Re:Delmar restoration 11 years 1 month ago #104435
Looks pretty good to me!
1970 Glastron V-142 SkiFlite
1965 Merc 500
1968 Merc 500
Re:Delmar restoration 11 years 1 month ago #104436
Looks OE great job
Re:Delmar restoration 11 years 1 month ago #104489
  • commando
Just joking here is what my boat color is a little bit of yellow, green for sure and a little bit of blue depend on where the sun hits it.I love it......got 2 coats on so when it is dry I'll board it down with 3 20 grit and spray 2 more coats on her.
Re:Delmar restoration 11 years 1 month ago #104495
  • Shelby18
  • Shelby18's Avatar
Love the color. It really brings out the lines also. I never noticed the extension lines that you took all the way back when it was primer. Very nice job!
Great to be on board.
Rick
Re:Delmar restoration 11 years 1 month ago #104729
  • commando
Did got some gelcoat on deck and started on the wood work but as my schedule is very tight so I made a rolling cart and rack so I can put her away for now until I have time I can just push her out of a corner and work on her again.
Re:Delmar restoration 11 years 1 month ago #104731
Looking great, yes that color is kewl
Re:Delmar restoration 11 years 1 month ago #104732
  • commando
I got the color from a fathers day card that my oldest daughters made for me when she was 5 yrs old.as you can see I have to rip the top corner to go get the gelcoat mix to match it.I think the card said I love you I love you when I was little I still love you.
Re:Delmar restoration 11 years 2 weeks ago #105634
  • commando
Re:Delmar restoration 11 years 2 weeks ago #105635
  • commando
So I took a day of work to sand and polish the bottom of the boat I think I'm happy with the outcome.now I can flip her over and get this project going again.
Re:Delmar restoration 11 years 2 weeks ago #105640
  • Shelby18
  • Shelby18's Avatar
Wow, that color really pops! It is looking really really good!
Rick
Re:Delmar restoration 11 years 2 weeks ago #105688
Outstanding!
  • 2
Time to create page: 0.147 seconds
We have 14041 guests and 2 members online
