TOPIC: Prop question
Prop question 11 years 9 months ago #102740
  • indovina
  • indovina's Avatar Topic Author
Hi Glassers,
Is there a chart or book that I can get to
tell if a prop is the right one for my engine,
I see many on Ebay,but not sure if they would fit
my 59 Johnson 35, need to know inch,pitch etc.
example-- Michigan SMC 51 is on this prop, would it fit
on the 35? Is there a Michigan book?
thanks
Happy Thanksgiving to all,
Rick
Re:Prop question 11 years 9 months ago #102748
There is a michigan wheel database over at AOMCI if you're a member, here's the stats on the prop:
Prop Number: SMC51
Brand: Evinrude
Model Name/Number: 35 H P
Horsepower: 35
Year: 1959
Prop Diameter: 10 1/2
Prop Pitch: 10
Number of Blades: 3
Blade Material: Aluminum
Recommended Use: 20'-24' Cruisers One Engine
KeyField: 4564
Good for a really heavy load but on a light boat RPM's would be way too high here's the listings for lighter boats:
Prop Number: SMC67
Brand: Evinrude
Horsepower: 35
Year: 1959
Prop Pitch: 15
Number of Blades: 3
Recommended Use: 12'-14' Light Runabouts 1-2 Passengers
KeyField: 4536
Prop Number: SMC59
Brand: Evinrude
Horsepower: 35
Year: 1959
Prop Pitch: 14
Number of Blades: 3
Recommended Use: 12'-14' Heavier Runabouts 1-2 Passengers
KeyField: 4540
Prop Number: SMC57
Brand: Evinrude
Horsepower: 35
Year: 1959
Prop Pitch: 13
Number of Blades: 3
Recommended Use: 14'-15' Light Runabouts 2-4 Passengers or Light Loads
KeyField: 4544
Prop Number: SMC55
Brand: Evinrude
Horsepower: 35
Year: 1959
Prop Pitch: 12
Number of Blades: 3
Recommended Use: 14'-16' Runabouts One Engine All Loads Skis
KeyField: 4548
Re:Prop question 11 years 9 months ago #102752
  • indovina
Thanks Al
Rick
Re:Prop question 11 years 9 months ago #102762
  • l98tpi
  • l98tpi's Avatar
The prop the 35s were shipped with, or the most common one is a 12 pitch. IIRC Use one of the online prop calculators to approximate what you need for the hull in question.
But first estimate the hulls speed with www.psychosnail.com/boatspeed/boatspeedcalculator There is a lot or required reading there about hull power requirements that will be enlightening.
We have 6138 guests and one member online
