TOPIC: need help getting a super seahorse 35 running
need help getting a super seahorse 35 running 12 years 3 months ago #98209
  • madbohunk
  • madbohunk's Avatar Topic Author
I have a ( model rdsl 21 b serial # 1954319)1959 johnson super seahorse 35 that came with my 65 shell lake, it hasn't run for 15 years so i need the do and don't to get her going. been sitting in a garage all that time. just pulled her home today. i need all the help i can get. so thanks in advance !!!!! madbohunk safe boating
Re: need help getting a super seahorse 35 running 12 years 3 months ago #98225
Needs a new impeller.
Needs flywheel pulled to inspect points and ignition coils.
If fuel sat in the carburetor it will need to be cleaned.
Needs gear oil drained and refilled.
Re: need help getting a super seahorse 35 running 12 years 3 months ago #98270
  • madbohunk
OK that a good start thanks
Re: need help getting a super seahorse 35 running 12 years 3 months ago #98274
When you pull the flywheel and inspect the points and coils take a close look at the wires all around. The old rubber insulation on the wires themselves dries out and will literally fall off and create a short to the block. If you find some just cracked I have had success using liquid tape to beef them up. When you change the lower oil make sure the shafts are sealed and not dripping after a few days otherwise you will get water in the gear housing. Electric start?? check the solenoid and connections in the box, those usually stay pretty clean unless they've sat under water or ice during winter months.
We have 8816 guests and one member online
