TOPIC: 56 Lark Prop Shaft seal housing
56 Lark Prop Shaft seal housing 12 years 6 months ago #93648
  • Paul
  • Thank you received: 7
Anyone know where I can get a NOS or very good prop shaft seal housing? Mine keeps wanting to cock in the gear case housing (I believe that's where my leak is coming from). I was going to try locktite and prick punching but I'd rather get a good one to start with.
Re:56 Lark Prop Shaft seal housing 12 years 6 months ago #93669
Ebay will almost always be the best bet. Does the outer rim of the housing appear worn? I'm having a tough time imagining how it is getting knocked out of alignment. That housing is held in position by the case. There is also a locating pin to keep the housing from spinning in the case.
Re:56 Lark Prop Shaft seal housing 12 years 6 months ago #93707
  • Shake
  • Shake's Avatar
not sure what part you are looking for, but this diagram on marine engines may be able to tell you the part number, or even provide you with a brand new part maybe....
www.marineengine.com/parts/vintage-evinrude-johnson/ITEM_2749/catalog.html?/parts/vintage-evinrude-johnson/ITEM_2749/ITEM_274900001.htm
page 10
maybe part # 303050???
www.marineengine.com/newparts/part_details.php?pnum=OMC0397186
Re:56 Lark Prop Shaft seal housing 12 years 6 months ago #93769
  • Paul
Yes, it's worn on one side a little so it cocks. Also yes, it's 303050. Ouch - that's a lot of cash for a seal housing. Hopefully I don't have to resort to that, but at least it's there as a last resort. Thanks both of you for your help.
Re:56 Lark Prop Shaft seal housing 12 years 6 months ago #93918
  • Paul
Found a NOS on ebay for 14 bucks. Thanks.
Re:56 Lark Prop Shaft seal housing 12 years 5 months ago #94692
  • Paul
Well, I went to put the new housing in and it's the wrong one. Too big. I'm guessing it was mismarked. Hopefully it will fit my 58 Lark when I need it.
We have 6539 guests and one member online
