TOPIC: 1976 remnote cable hook up continued.
1976 remnote cable hook up continued. 13 years 1 month ago #84015
  • 59Hustler
This is a continuation I could not reply on the original. due to the sidebar. I found the issue was I was using early oring and guide bars(cable ends) they changed them in 1973 mine were from th 60's. I ordered a trunion lock and the new cable ends. In the meantime I checked the comprssion. It was not good at first. 40. 90 and 90. This was with a slow crank. I then shot some premix in and got 110 on all cyl.
I got her to start on the muffs and she ran great. I then rechecked the compression warm w a fast crank 130,135 and 135 comp.I am watching the no.1 or top cyl.
Re: 1976 remnote cable hook up continued. 13 years 1 month ago #84030
That is good to hear.
My 73' 65HP initially gave me 100, 100, 80.
Once running they are all 95 +/- 3 psi.
I am on season 5 now.
Re: 1976 remnote cable hook up continued. 13 years 2 weeks ago #85437
  • 59Hustler
The real answer to this. I did need the new casing guide and oring and to get allen set screws to replace the slotted screws that came with the old casings. Then I had to read the manual for about the 30th time (hey I am dense). The shift arm needs to come forward which I had done and it clicked into place so I thought it was all the way forward, (The shift arm also swung all the way back). The manual also states "it may be necessary to turn the prop shaft in-order -to shift into forward" this I had not done. When I did that the shift arm suddenly was able to come forward another inch and the casing slid right on.:)
Now I feel dense but I am posting this incase someone else has this same issue.
We have 10870 guests and one member online
