TOPIC: Some questions on a selectric shift
Some questions on a selectric shift 13 years 8 months ago #74681
  • Jim L
  • Jim L's Avatar Topic Author
Can someone tell me if you always need to go through neutral when shifting from forward to reverse?I try to remember to do that,but I just noticed I didn't in a video I posted.Also generally how far towards the front does the throttle go to WOT.Mine don't go that far. I'm used to the Johnson electramatic shifter.jim
Re:Some questions on a selectric shift 13 years 8 months ago #74685
The way the shifter is set up it is going into neutral as it goes into the other gear. Just do not change it at a high rpm.
One of the things I loved about our 1969 115 was being able to go from forward to reverse, or vice versa; with out much movement ...great when teaching someone to ski, or pulling to a dock with the tide going one way and the wind the another
Re:Some questions on a selectric shift 13 years 8 months ago #74706
Agreed at idle it can be shifted directly from forward to reverse.
With a heavy bronze prop you might want to go to nuetral first for a couple of seconds.
We have 7392 guests and no members online
