TOPIC: Can I make a gasket?
Can I make a gasket? 14 years 4 months ago #63534
  • Shipster
  • Shipster's Avatar Topic Author
Hi All,
Just curious if it is possible to do. Seems to me that if you have heat resistant material it should be a pretty simple process. Am I way off base here? Thanks in advance.
shipster
Re:Can I make a gasket? 14 years 4 months ago #63549
  • riceman
  • riceman's Avatar
we do it with cars all the time. i don't see why not. get some gasket material appropriate for the application and you should be okay. not a head gasket or anything, but most other stuff should be okay. you'll probably find that buying the proper gaskets ends up being comparable in price but has a nicer end product though.
what's the application are you trying to make a gasket for?
Re:Can I make a gasket? 14 years 4 months ago #63553
Here they used paper, however you can used most any gasket material that you can buy at most auto parts store
Re:Can I make a gasket? 14 years 4 months ago #63569
  • frog
  • frog's Avatar
  • Thank you received: 3
i made most of the gaskets for my old kholer 12 hp lawn mower engine from cheerio boxes it still running and no leaks. that was about 5 years ago. frog
We have 10614 guests and one member online
