TOPIC: 60 slickcraft 58 evinrude wiring
60 slickcraft 58 evinrude wiring 14 years 5 months ago #62028
  • curse
  • curse's Avatar Topic Author
I have a 1960/1961 slickcraft and am trying to figure out the wiring. My motor is a 1958 evinrude 50 starflite. The boat has a 3-pole ignition switch and motor has a magneto.
Do i need a 6-pole switch with the 2 "m" and "choke" terminals? Also, do i need a voltage regulator or can i get by without one? The only thing the battery is going to do is start the motor....no radio, nav, etc.
Please give me any advice or tips!
1960 slickcraft catalina
1963 g-w invader ski-bird
Portage Michigan
Re: 60 slickcraft 58 evinrude wiring 14 years 5 months ago #62061
If no luck here, I would suggest trying the Antique Outboard Motor Club's Ask-A-Member Forum at www.aomci.org
Re:60 slickcraft 58 evinrude wiring 14 years 5 months ago #62066
  • curse
Thanks HandyAndy. I'll give that a shot since i can't get an answer here or at iboats.
Portage Michigan
Re:60 slickcraft 58 evinrude wiring 14 years 5 months ago #62781
  • curse
Where can i get a pinion gear screw shaft and a rubber cushion. Pics below of damaged parts. Or...is there a fix or way to get around it if parts aren't available? The pinion gear comes down and sticks on the screw shaft, so it does not go up to meet flywheel.
Portage Michigan
Re:60 slickcraft 58 evinrude wiring 14 years 4 months ago #62902
Sorry I did not post sooner...Been working hard..Summer is here in TX
here is the wiring for that motor..and the switch. You must have 2 M post. The motor is killed by joining the two mags together...not grounding
Post an WTB ad in the AOMCI Webvertize for you starter parts. It is free, all you have it do is sign up..We did not require signing up till a bit over a year ago...we were getting spam and that slowed it down
www.aomci.org/cgi-bin/yabb2/YaBB.pl?board=Webvertize
Re:60 slickcraft 58 evinrude wiring 14 years 4 months ago #62906
  • curse
Thanks, I did find and use that diagram but i like the colored version better. I'm pretty sure i have the wiring all sorted out. I wired it and didn't have power out to the starter at first. Found bad wires in the harness to the front and wiring was original so i replaced all of it and starter did turn over.
As for the starter bendix... i found a starter and bendix housing locally. I'm waiting to get it and hopefully it will be in good condition.
Is there something that can be used to replace the rubber cushion if needed in the future? It does not seem like they would last forever.
Portage Michigan
We have 10567 guests and one member online
