TOPIC: What's Up With My Selectric? Slipped out of gear
What's Up With My Selectric? Slipped out of gear 15 years 2 months ago #29440
1966 Starflite 100 with electric shift (now running well, for those of you who've made suggestions for me in the past).
About 3/4 throttle and it slipped out of gear. Wouldn't go forward or reverse. Opened control housing and the three wires to the shifter buttons were warm. Not hot, just warm. Fiddled with the knife connectors inside the motor housing that connect to the solenoid and it then shifted into reverse but not forward.
I'm about to crack it open and look at the solenoid, but if that's not it I'll be looking for suggestions.
Update: Solenoid leads to ground read 0.6 ohms and there is continuity between the two solenoid leads, I assume that means bad things for the solenoid. Next question: How do I get it out?
Re: What's Up With My Selectric? Slipped out of gear 15 years 2 months ago #29446
First of all they are NOT solenoids down in there.
There are 2 electromagnets that pull / attract a spring over which then wraps around the drum.
Do both read the same OHMS when you test with one meter lead on the coil wire and the other meter lead on the case/ground ????????
Testing to both leads means nothing.
Post results.
I am thinking the tab broke off the forward spring
Re: What's Up With My Selectric? Slipped out of gear 15 years 2 months ago #29450
  • g3jim
  • g3jim's Avatar
when these failed I thought they were supposed to fail into forward gear to get you back in?
Re: What's Up With My Selectric? Slipped out of gear 15 years 2 months ago #29451
WRONG !!
The electramatic does not default to forward gear.
That started with the hydro-electric shift in 68 on the 3 cylinder 55 HP.
The first V-4 with hydro-electric was 1969 and lasted till 1972.
All electric shift units are a thing of beauty , well engineered and reliable.
Re:What's Up With My Selectric? Slipped out of ge 15 years 2 months ago #29454
wavetrain75 wrote:
...Update: Solenoid leads to ground read 0.6 ohms ...
professor wrote:
--Do both read the same OHMS when you test with one meter lead on the coil wire and the other meter lead on the case/ground ????????
How do I diagnose a broken spring tab?
Re: What's Up With My Selectric? Slipped out of gear 15 years 2 months ago #29455
  • Jim L
  • Jim L's Avatar
professor wrote:
WRONG !!
I agree.The only trouble I've ever had with an electric shift was the forward wire going down to the gear case breaking in two after 40 years service and I still got back to dock(reverse wire didn't break) :laugh:
Re: What's Up With My Selectric? Slipped out of gear 15 years 2 months ago #29457
Wavetrain 75
Re: What's Up With My Selectric? Slipped out of gear 15 years 2 months ago #29458
Wavetrain 75
There are 2 electromagnets in there , they are NOT solenoids !!
I have about 10 of these lower units / can repair them without so much as glancing at a manual.
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29461
Need to revise previous statement. Green wire gets a reading of 5.9 ohms, blue wire gets a reading of 0.6 ohms when grounded to the block.
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29462
One meter lead on green and one on the gearcase reads ??
One on blue and the other on the gearcase reads ????
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29467
professor wrote:
One meter lead on green and one on the gearcase reads ??--
5.9
0.6
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29472
Motor stopped
Disconnect shift wires at the motor.
Control in " forward "
Turn key to " on "
Touch green to green at the motor.
Then touch the same green to blue.
Do you get the same little " spark intensity "
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29478
The lower unit is off the motor, it was leaking water so I had to get it off anyway. Also the blue and green wires are reversed inside the lower unit (forgot about that until now, but at the knife connectors the colors are reversed to make the shift buttons do what they say).
That said...
Now a reading on either wire from the lower unit reads about 6.3 ohms, a change from an hour ago. Jiggling the wires around did not change the reading.
Connecting power to either wire resulted in a nice little spark of about the same intensity, but only the BLUE wire produced a satisfying "click" sound from the gear case.
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29479
I would say you have a broken tab on the forward spring.
The " click " means very little.
Your OHM readings are good, they should be the same.
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29480
Can a civilian replace the spring (I assume they're available) or is it one those where you need exotic tools if you don't want to be chasing the Godzilla of slinkies around the garage?
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29506
On ----shop.evinrude.com
They are listed as not available new for the 68 model ( same lower unit )
NO SPECIAL TOOLS REQUIRED TO REPLACE A BROKEN SPRING.
Well maybe a slide hammer with 1/4-28NF thread.
You have tested both forward and reverse engagement ( 12 volts applied )with the lower unit off.
Should drag one way when turning the prop and engage after 1/4 turn going the other way.
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29509
Forward spring is the one furthest from the prop, right? Reverse spring is fine (assuming it's closest to the prop).
Forward spring engages under no load: I can manually turn the drive shaft and it will engage the prop shaft when current is applied.
After work today I need to test it further to see if it slips when resistance is applied, but as of now it appears to be working normally.
Springs are on ebay for about $200. Yikes.
The shift wires don't look to be in the best condition, thinking it would pay to replace those. Is there a trick to that? Oil pump and drive shaft might be coming out tonight, but only if necessary.
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29510
Forward electro-magnet is the one furthest from the prop.
Drive shaft has to come out in order to remove the forward clutch spring / hub / gear assembly.
Electromagnet stays in the housing and may not have to be removed ( except for wiring repairs )
Pretty simple stuff really !!
Re: What's Up With My Selectric? Slipped out of g 15 years 2 months ago #29580
Prop shaft does not slip vs. the drive shaft when forward magnet is energized. I could feel the spring tension but it did not slip.
However, the wire to the forward magnet has continuity to ground, even though it still seems to work. So I'm thinking it's a wire. Good news it's a lot cheaper, bad news it looks like a PITA.
But this weekend is supposed to be cold an rainy anyway so I'll need a good project. And I can inspect the spring while it's out.
Re: What's Up With My Selectric? Slipped out of g 15 years 1 month ago #33334
Are you using Type C oil in the lower unit? It's required on my 64 40hp Seletric. If you use the regular stuff, it will slip out of gear under load.
Todd (aka thetudor)
1964 Custom Craft Aqua Ray
1959 Glastron Seaflite
1959 Tomahawk Spirit
Re: What's Up With My Selectric? Slipped out of g 15 years 1 month ago #33375
thetutor
Your electric shift will work with other oils for a while!
Using other oils will lead to damage of the clutch spring and hub later , not on the first day of use.
We have 5997 guests and no members online
