TOPIC: Gas tank Questions
Gas tank Questions 15 years 9 months ago #24775
I have two questions; one on a source for old style johnson/evinrude pressurized tanks, the second is on repairing the newer style (post 1960)portable Johnson/evinrude/omc pickup units.
I have three small 5 1/2, (2) 15 hp 1956 Johnson outboards. Is there a source for the old style pressure tanks? I have been watching ebay and craig's list. Did not know if there was a place to buy just the tanks without fitting/handle set up. Tanks have developed leaks
On the newer post 1960 tanks. I have a couple that weep/leak gas when underway around the gas tank fitting. Looking at the exploded drawing of the pickup unit I can see two "O" rings that I suspect are the problem. Question is how do I get to them. The drawing shows a couple of plugs that hold them in. Does anyone know how to get these plugs out?
Re: Gas tank Questions 15 years 9 months ago #24783
Drill a small hole in the plugs and then pry the plugs out.
Replace the o-rings and install new plugs.
Used to do this for people while they waited ( customer service it was called 40 years ago )
Now when I ordered the parts the dealer said " i just sell people new tanks "
You could always tell there was a problem as one pin would stick out further than the other.
Re:Gas tank Questions 15 years 9 months ago #24791
Thanks, where do I find the plugs and "O" ring? Are they dealer items or could I find them at Nappa or big box?
Re: Gas tank Questions 15 years 9 months ago #24794
Any OMC / BRP dealer should have them " in stock "
They used these tanks for many years.
shop.evinrude.com
has the part# I am sure.
Order 3 plugs in case you mess up the first in your repair.
Re: Gas tank Questions 15 years 6 months ago #31976
You could always convert them to single line like this.
www.sschapterpsa.com/ramblings/Converting_dual_fuel_line.htm
Re: Gas tank Questions 15 years 5 months ago #32014
Sierra (NAPA) part # 18-7111
OMC part # 0301824
Re: Gas tank Questions 15 years 5 months ago #32026
There is also a really small O-ring where the pin comes out of the housing.
If leakage is persistant replace it too.
I ordered parts to repair these tanks one time and the dealer said
" what are you doing that for , I just sell people a new tank "
Re: Gas tank Questions 15 years 5 months ago #32038
Check with these guys if they don't have what you need they can tell you were to get it. Post your questions its free.
www.aomci.org/cgi-bin/yabb2/YaBB.pl?board=askamember
Mike aka pathfinderz1
We have 8844 guests and no members online
