TOPIC: volts while running wot
volts while running wot 10 years 1 month ago #127279
What should be the volt reading at wot. New battery, at idle she's 12 - 13 volts. wot is around 15. Not running any accessories.
Re:volts while running wot 10 years 1 month ago #127283
That is fine. Wouldn't be surprised to see 16 after a long run.
Re:volts while running wot 10 years 1 month ago #127339
  • Ike
  • Ike's Avatar
  • Thank you received: 14
Volts shouldn't change much. 14 to 15 is normal. What should change is amperes. Amperes should go up.
Peter D. Eikenberry
newboatbuilders.com
We have 7006 guests and no members online
