TOPIC: Increase HP and keeping economy on a '79/85hp ER
Increase HP and keeping economy on a '79/85hp ER 10 years 2 weeks ago #121848
  • g3bill
  • g3bill's Avatar Topic Author
Increasing HP and keeping economy close to original on a '79/85hp Rude, Is there a place to look for small DIY modifications that wont cost tons? Maybe opening the carb a bit and different reeds or whatever. prop, mine is stock alum 3 blade? Just thinking to increase speed from 30 to about 35. Bill
3 cd g3's
1 seafair sedan
Re:Increase HP and keeping economy on a '79/85hp ER 10 years 2 weeks ago #121881
All power increases use more fuel -- there is little that can be done for efficiency. Bigger carbs/jets and lighter reeds will add power, but will eat more fuel for sure.
Re: Increase HP and keeping economy on a '79/85hp ER 10 years 1 week ago #121882
  • Thank you received: 128
Bill, a stainless prop might give a bit better performance. If I recall, the OMC stainless props have thinner blades which slice thru the water with greater ease.
You might also take a look at the transom height of your motor; you may be able to raise it up a bit for less drag. I'm assuming it's on the Seafair Sedan and that's not exactly a hi-perf boat, but most rigs do respond to raising the engine a bit from std height.
The biggest concern in doing so would be ventilation during cornering and when the engine is trimmed out. A 4-bladed prop would help with that, although 4 blades ain't necessarily gonna be faster than 3 blades!
Pretty much any older, crank-rated 2-stroke is gonna suck down fuel at a rate per hour of its HP rating divided by 10, at full thottle. I.e., your 85hp will use approx 8.5 GPH at full throttle.
It's a little trickier when trying to figure out a newer motor that is prop-rated, they're gonna burn more at WOT than that formula would indicate, since the formula only works with crank-rated HP values.
If you were to repower with an E-TEC that'd probably be the most fuel-efficient (albeit very expensive) way to go. A 4-stroke is efficient as well, but the weight penalty offsets a lot of that.
Check out this 90hp E-TEC HO, Sweet!
www.boattest.com/engine-review/Evinrude/18500074_E-TEC-90-H-O-_2014
www.thefisherman.com/index.cfm?fuseaction=feature.display&feature_id=676&ParentCat=3
That's a "90" 4-cyl that puts out almost 100HP at the prop!
Even the 3-cyl 90hp would most likely move your boat faster and more efficiently than the old 85hp Beast:
org-www.evinrude.com/en-us/engines/etec_inlines/etec_90_inline
Lighter than its 4-cyl mate, as well.
HTH........ed
Glasspar Tacoma
Glasspar Tacoma
05-04-2026
1962 Scott - last chance!
( / Parts / Miscellaneous)
04-14-2026
We have 9275 guests and no members online
