TOPIC: A question about fogging an engine.
A question about fogging an engine. 11 years 3 weeks ago #116152
  • Jim L
  • Jim L's Avatar Topic Author
O K, time to ask a stupid question . If your boat sets in a heated basement all winter ,do you still need to fog it.
Re:A question about fogging an engine. 11 years 3 weeks ago #116154
  • frog
  • frog's Avatar
  • Thank you received: 3
yes, jim. if your not going to start it every week the cylinders will dry off. fog it with a lot of oil and put oil in the spark plug holes and crank it over. leave the plugs loose to clean out the oil in the spring. and I would put stabilizer in the fuel. just my thoughts. greg
Re:A question about fogging an engine. 11 years 3 weeks ago #116156
Just learned something that I need to know.
Re:A question about fogging an engine. 11 years 3 weeks ago #116166
  • Jim L
Sounds like good advice ,Greg. I have squirted some oil in the cylinders(when I'd remember to) in the past. I have already changed the foot oil plus put a new prop shaft seal on. I'll pop out the plugs and give them a squirt.
Re:A question about fogging an engine. 11 years 3 weeks ago #116168
If you go out on the lake early some mornings there might be enough mist/fog. Just do a good run.
Other than that, ditto on what Greg wrote. I too store in a heated garage but I don't "fog" the engine running, I just do the spark plug fogging oil in the cylinders and turn it over a few times but I do add StaBil marine to the gas. Last year I had an old motor with stuck rings with low compression, sprayed fogging oil and sea foam in the cylinders and let it sit over winter, by spring everything was free with high compression.
We have 12969 guests and no members online
